Hopefully getting a MorphOS Machine soon... question time!
    Everblue
    Posts: 170 from 2004/1/6
    I am thinking of getting a MacMini G4 machine for MorphOS and I have a couple of questions :)
    1. I know there are MacMini machines with 32mb of VRAM and others 64mb.... While I'd assume the 64mb version is ideal, are there real advantages to get a 64mb machine, for MorphOS usage?
    2. Is there anything else I should know? (dunno things like bugs, compatability issues etc).
    Thanks!
  • »05.12.11 - 08:14
    Simon
    Posts: 809 from 2008/7/6
    All complaints I hav ever seen concerning Macmini were about networkspeed and soundvolume ... both are more less easy to solve if encountered if I did understand that well.
    About the VRAM ... it depends on what you call " a real advantage ". If you don't use any eyecandy there is no advantage. Otherwise I would really suggest you get that 64Mb VRAM one.
  • »05.12.11 - 09:11
    Everblue
    Hmmm interesting. Maybe someone else knows a bit more about the network speed + sound volume issues?
  • »05.12.11 - 09:25
    TheMagicM
    Posts: 1220 from 2003/6/17
    I have a G4 Mac Mini for sale.. $250 + shipping with MorphOS 2.7 registered.
  • »05.12.11 - 09:43
    Everblue
    What specs please? How much Video Ram?
  • »05.12.11 - 09:50
    Personally, while the compact form of the Mac Mini is attractive, I'd look for a Powermac.
    Its more expandable and you can install faster processors, sound, video, and USB cards, etc.
    And you'll probably pay less for a Powermac.
  • »05.12.11 - 13:08
    Everblue
    Unfortunately space is a big issue, and well Macmini is more portable =)
  • »05.12.11 - 13:29
    Yes, at about 40 pounds the Powermac is somewhat bulky.
  • »05.12.11 - 21:45
    TheMagicM
    1.4ghz, 160gb hd, 1gb ram. Pic is in the for sale section.
  • »06.12.11 - 02:12
    TheMagicM
    Oepabakkes
    Really? Fact or just pulling it out from somewhere? I have a 32mb Mac Mini and I dont have any issues.
  • »22.12.11 - 21:44
    Posts: 12570 from 2003/5/22
    MorphOS 2.4 had a bug where only 32 MiB of the 1.5 GHz version's 64 MiB VRAM were used by MorphOS under certain circumstances. I was experiencing this bug back then and it really caused issues with my config (enhanced display, 1680*1050 resolution at 32 bit depth, several screens) such as crawling graphics update.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6560&forum=11&start=19
  • »22.12.11 - 21:57
    stephen_robinson
    Posts: 746 from 2007/4/22
    I did notice a difference between my 1.42gHz and 1.5Ghz macmini, but only when I was using more than 1 screen.
    Personally I'd advise getting the 64gb version, other peoples milage may vary etc etc.
    Also if you're using MacOS X increasing the memory to the maximum of 1gb is almost essential. TBH Leopard hardly speedy muiltasking with anything less than 2 gb
    [ Edited by stephen_robinson 23.12.2011 - 05:27 ]
  • »23.12.11 - 04:20
    cip060
    Posts: 152 from 2010/7/30
    Macmini 1.25 32 Vram
    Macmini 1.42 32 Vram
    Macmini 1.50 64 Vram
    MorphOS 3.0 will support all AGP specification accordingly MacMini 32 Vram avra'la chance 'if needed to make the swap with the system memory as video memory and use it every time you will serve'
  • »23.12.11 - 08:13
