Posts: 2095 from 2003/6/4
Fab wrote:
Better don't hold your breath on Java. It won't come from me in any case. :)
For Flash, i'll probably release a first version when i have implemented sound. Though i wonder if it's worth releasing it, considering the speed and people expectations.
I think lack of speed shouldn't hold you back in releasing a beta. I it is printed boldly on the release that the speed is low most ppl should notice it. Nevertheless there will of course some ppl complaining about this 'crappy speed', but there are always ppl complaining. I think the most valid reasion for holding back a release would be a strong instability. But as long as it is fairly stable I think it is okay to let it go.
And regarding Java,there seems to be some momentum again in the JAmiga project. While it is generally good to expect the least and keep teh hype low, there seems to be some progress at least according to http://www.pegasosforum.de/viewtopic.php?p=42318&sid=95b988f87c56b128df718d2d01c03b35#42318
