Flash
    xyphoid
    Posts: 870 from 2008/7/11
    So.... we don't have it because of a licensing issue?
  • »15.09.11 - 20:37
    analogkid
    Posts: 706 from 2004/11/3
    Yes, because Adobe sees no sense in porting Flash to MorphOS...
  • »16.09.11 - 02:45
    stephen_robinson
    Posts: 746 from 2007/4/22
    Or continue to support it for PPC Mac-OSX anymore.
    And if they can't/won't do it for them, what chance has MorphOS?
  • »16.09.11 - 04:19
    Jupp3
    Posts: 1193 from 2003/2/24
    Yes. Because Adobe hasn't released the official flash player (the only "somewhat functional" one around) under open source license, it's not possible to port it to any unsupported platform (unless Adobe themselves want to do it, which they don't).
    Personally I wouldn't call that "licensing issue", just closed source software.
    Generally licensing says what you may and may not do (like port to other platforms). Being closed source doesn't (as such) forbid that, just makes it practically impossible.
    Of course there are 3rd party open source solutions, but none of them are very compatible, and we have one of those already anyway. Gnash isn't much better yet, but if that changes some day, a port might be considered.
    [ Edited by Jupp3 16.09.2011 - 13:30 ]
  • »16.09.11 - 08:28
    xyphoid
    (Adobe hasn't released the official flash player (the only "somewhat functional" one around) under open source license, it's not possible to port it to any unsupported platform (unless Adobe themselves want to do it, which they don't).
    isn't there a demo or evaluation ver similair to what android 2.2 uses or is this what you were referring to above?
  • »16.09.11 - 21:18
    Posts: 12454 from 2003/5/22
    > isn't there a demo or evaluation ver similair to what android 2.2 uses [...]?
    Android is considered a supported platform by Adobe and thus runs the official Adobe Flash Player, which is closed source like all the other Adobe Flash Player versions.
    https://market.android.com/details?id=com.adobe.flashplayer
  • »17.09.11 - 05:58
    xyphoid
    What's the deal with Adobe Air?
    Another dead end for MorphOS?
  • »11.11.11 - 15:03
    Krashan
    Posts: 1107 from 2003/6/11
    In what way it may be a dead end for MorphOS?
  • »11.11.11 - 15:49
    xyphoid
    well, can it be implimented into the OS or mainly OWB?
  • »11.11.11 - 16:19
    Go back to Jupp3's reply in posting #5. What holds true for Adobe Flash holds true for Adobe AIR all the more.
  • »11.11.11 - 16:35
    xyphoid
    Then the answer should have been the classic Piru response...yes!
  • »11.11.11 - 16:46
    Krashan
    It can't. So what? Silverlight and many other technologies can't as well.
  • »11.11.11 - 17:49
    boot_wb
    Posts: 874 from 2007/4/9
    Ah-ahhh Saviour of the Universe!
    /me runs
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »12.11.11 - 14:36
