Morphos Key
    gothor
    Posts: 33 from 2011/4/6
    my Mac Mini is death an i will buy a PowerMac G4. Can i user my old Keyfile? I have this question, because i don't know is the keyfile registrate only for my Mac Mini.
    Thanks for your info
    Gothor :-)
  • »10.10.11 - 21:12
    Posts: 1932 from 2003/10/19
    I hear if you can show proof that the mini is dead and is no longer functional you can get a replacement key for a new machine. Maybe a video of it failing to power on or one of you smashing it sent to the team with do it?
  • »10.10.11 - 22:37
    Go to the official MorphOS Developers website and contact them directly about getting a new keyfile replacement for your new G4 PowerMac. They will tell you how you can confirm with them that you can no longer use the keyfile you have for your G4 MacMini.
    How did it break? Did it just stop booting one day? Have you tried to find out what is wrong with it, or fix it your self?
  • »11.10.11 - 02:52
    Simon
    Posts: 809 from 2008/7/6
    Not sure how they can really tell the hardware is death without actually testing it...
    Anyway I had a faulty quiksilver that was registered and I had no problems getting a new keyfile for a replacement machine without the need for violence.
  • »11.10.11 - 08:27
    gothor
    Thanks all for yor information. I will contact the Developer.
  • »11.10.11 - 10:17
  • SMF
    SMF
    Posts: 36 from 2004/3/2
    Buy a new mac with warranty next time
  • »05.11.11 - 08:27
    Simon
    You are so funny...
  • »05.11.11 - 10:13
    connor
    Posts: 650 from 2007/7/29
    G4? Where?
  • »05.11.11 - 10:13
    Simon
    @Connor. I think it's called "sarcasm"
  • »06.11.11 - 11:33
    analogkid
    Posts: 688 from 2004/11/3
    Why do you think it's irony? You can buy refurbished PowerPC Macs with warranty.
    [ Edited by analogkid 06.11.2011 - 13:06 ]
  • »06.11.11 - 12:05
    Simon
    One can get suspicious after being exposed to trolls for the last 10 years or so, I suppose. So if that sentence is ment as you tell me, I have to apologize ;-)
    That said .. how long will that warranty be ? 60 days ? And what is refurbishing on a mac ? Cleaning the dust out and -maybe- a new optical drive and harddrive ? Anyone can do that with a little effort.
  • »06.11.11 - 12:15
