Some questions
    phoenixkonsole
    Posts: 140 from 2010/8/4
    in short:
    1) How far is WIFI support for MOS. I have read somewhere that Neil(AROS wifi bounty) is helping you.
    I am interested in a Powermac so a PCI solution would be my favorite.
    2) Is it possible to use a TV tuner card with MOS?
    3) How can i print? Are there any printer drivers besides Ghostscript? (GS is fine, i am just curios if there is more support)
    How much faster(if at all) does a 1GHZ Quicksilver run compared to a Peg II ?
    Thank you in advance : )
  • »01.11.11 - 21:39
    Posts: 1521 from 2003/2/24
    2. Analogic tv cards are supported. No idea where just thing is still used.
    3. Only printers listed here are supported. TurboPrint is integrated to MorphOS but it is quite old.
  • »02.11.11 - 08:09
    Henes
    Posts: 507 from 2003/6/14
    Often forgotten but you can also use any application supporting Postscript (there are quite a few) to print to any Postscript printer not mentioned in this list. Mostly lasers but not only...
  • »02.11.11 - 08:48
    Simon
    Posts: 809 from 2008/7/6
    Printer support could be better. I did try it with my Ricoh Gelprinter but no luck so far.
    Powermac 1 Ghz has faster memory access and is faster as a Peg2 .. but I don't think it's that a big difference.
    For the Wifi support, best to ask Neil I think.
  • »02.11.11 - 09:25
    Miky060
    Posts: 694 from 2003/2/24
    To have a bigger performance difference buy a PowerMac MDD, if possible 1,25Ghz or better.
  • »02.11.11 - 09:52
    Henes
    Oepabakkes,
    Ghostscript does not handle at all the proprietary RPCS language used by this printer. See http://thread.gmane.org/gmane.comp.printing.ghostscript.devel/3476
    So I am not sure such device is usable outside the Windows world. Maybe if it got some PCL compatibility...
  • »02.11.11 - 11:12
    Itix wrote: Quote:
    I have a ATI Radeon 9700Pro All-in-Wonder video card with an analog TV tuner on it that I was hoping would work on MorphOS2.7 in my G4 PowerMac. I have to re-flash it for use in a Mac computer first, as it is a PC video card, and tape pins to make it work in the AGP slot of the G4 PowerMac, instead of a PC or G5 PowerMac. The last time I looked into this topic, I think I found that only a few analog TV tuner cards were supported by MorphOS and had only been tested in the Pegasos1 & 2 computer systems. Has anyone tested a TV tuner card in a G4 PowerMac?
  • »02.11.11 - 16:05
    Krashan
    Posts: 1107 from 2003/6/11
    Almost all Ricoh printers, including gel GX 3000, 5000 and 7000 families, have built-in PCL 5e and PCL 6 emulation. This is factory mounted, not an option (most of Ricoh devices have PostScript as option). Then they may be tried with PCL/LaserJet drivers.
    Only some low-budget devices, which are either rebranded Samsungs, or have Samsung printer controllers, are Windows GDI devices, and have PCL as (problematic) option. Those include models like multifunctions MP2000L/LN (not SP/SPF), MP161L/LN (not SP/SPF) and some small A4 multifunction color devices for example SPC221/231 models.
  • »02.11.11 - 16:40
    Simon
    It's a Ricoh GX e2600. I would already be happy if it prints black and white text so I can print some Amigaguides from software I want to install on my Amiga(compatibles) with having to travel from the one I am working on and the one with the manuaml onscreen. So if anyone can take a look at the manual/specs of my printer and can point me in the right direction I am a very happy man who has again one reason less to fire up the old WindowsXP box.
  • »02.11.11 - 16:47
    Krashan
    In this case you are out of luck. This is a low-end model with many features removed. No PCL.
  • »02.11.11 - 16:54
    Simon
    I do have a Dell 1100 somewhere ... maybe that will work ?
  • »02.11.11 - 17:02
    phoenixkonsole
    i have an Postscript printer here because of AROS. So PS/GS is ok for me. Also i have an Lexmark which acts as HP Deskjet 500C... but it has only a parallel connection.
    The only reason to by a Peg 2 is because of the fact that i can run MOS, AOS and AEROS on one box.
    I have now some auctions on the watch list.
    One Peg 2 and several Macs
  • »02.11.11 - 17:03
    Krashan
    No, it is a "winprinter" aka GDI. Looks like another rebranded Samsung (ML-16xx series). If you want MorphOS compatible printer (having PCL or PostScript) you have to skip the "lowest prices" zone...
  • »02.11.11 - 17:11
    Simon
    The Dell I bought years ago for peanuts with two new toners because my wife had to print a lot for school. A month ago I bought the ricoh thinking it wasn't a bad deal... actually it wasn't when your windows only user. So I gues sI have to follow your advice sooner or later....
  • »02.11.11 - 17:27
    The Powermac also has a true AGP 4x slot which might make some video card operations faster.
  • »02.11.11 - 17:31
    phoenixkonsole
    hehe...
    one question left:
    Since i would like to focus on new Software creation for AOS and MOS in the next year....
    I assume that the PEG2 can dualboot AOS4 and MOS? Or can i have only one of them?
  • »02.11.11 - 21:29
    Divinity
    Posts: 532 from 2009/9/8
    phoenixkonsole,
    sure, use Boot Creator 1.2 for exemple http://www.tbs-software.com/morgoth/projects.html
    here a guide http://www.nonsoloamiga.com/forum/viewtopic.php?f=25&t=251
  • »02.11.11 - 21:34
    @Oepabakkes,
    I have a Star Micronics NX1000 Color 9pin printer that is "Amiga" compatible I could sell to you.  :-)
    (Not what you had in mind?)
  • »03.11.11 - 02:31
    Get27
    Posts: 90 from 2004/8/23
    Quicksilver have 1x UDMA66 and 1x UDMA33 IDE ports - Pegasos2 have 2x UDMA100 IDE ports.
    I tested same HD on these machines and it's really slowly on quicksilver.
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »03.11.11 - 05:23
