Amiga Event Essen and MorphOS Team
    maurensen
    Posts: 358 from 2003/10/3
    At the end of the year I'll move to a new apartament with a spare room. I hope to be able to get a cheap desktop Mac and rejon Amigaland (hoping my gf will not monopolize my hobby room:-) )
    Good work MorphOS team!
    Hola
  • »27.07.10 - 11:15
    jacadcaps wrote:
    Eh, iBook? There was not a word said about iBook support in Essen. In fact, afaik we only have 1 MorphOS Team member that even owns one - all others have moved into PowerBooks. While I had MorphOS working on my 1.33 iBook sometime around 2006, it needs much more work than the last PowerBook revisions - therefore don't expect anything. It might happen one day (if bigfoot is bored enough to do ADB keyboard/touchpad support), but it may as well never happen.
    I am guilty of including something about the G4 iBook as a possible target in one of my postings, but meant it as only a future possible target, not that anyone had started work on it already. Partly wishful thinking as I already have access to a G4 iBook and could try it out if released and partly just an assumption that the last revision of the G4 iBook was reported to have a very similar configuration to the G4 MacMini and therefore would likely be easy to complete. Sorry for creating any confusion.
  • »27.07.10 - 17:30
    Posts: 12572 from 2003/5/22
    Addendum:
    > bigfoot's picture says 1350 MHz, PA6T has 1067 MHz
    Seems my comparison was not quite fair:
    http://www.amiga.org/forums/showpost.php?p=572946
    So it's more like 1350 vs. 2133 (or 675 vs. 1067) MHz according to that.
  • »01.08.10 - 22:36
    According to http://www.a-eon.com/pics/ranger.jpg the FSB with a 1.8 GHz PA6T runs at 900 MHz. So I guess for the proclaimed 1000 MHz it requires the PA6T to run at 2.0 GHz, and for the FSB to run at the max spec of 1067 MHz the PA6T would have to run at 2.13 GHz.
    Edit: More evidence for the 900 MHz FSB:
    http://hdrlab.org.nz/benchmark/gfxbench2d/OS/AmigaOS/Result/498
    [ Edited by Andreas_Wolf 02.01.2012 - 01:28 ]
  • »08.09.11 - 09:32
    > runs at 900 MHz.
    "The X1000 supports 1.8V DDR2-800, unbuffered, non-ECC, DIMMs."
    http://www.solie.ca/files/0e0dea75818f2aab94fd140f2851f697-14.html
    As I'm not sure that running the RAM 12.5% overclocked is a good idea I'd rather recommend using DDR2-1066 DIMMs (running underclocked) instead of DDR2-800 DIMMs.
  • »25.09.11 - 20:44
