couple of questions
    jimh54
    Posts: 10 from 2011/8/28
    I want to set up the vnc server on my Mac mini morphos install.
    1) How can I find the internal ip address in morphOS. I have it set to DHCP.
    2) how do I set a login password for MorphOS?
  • »08.09.11 - 12:58
    Posts: 2217 from 2003/2/24
    1) Type "ifconfig" in shell.
  • »08.09.11 - 14:31
    Ruud
    Posts: 335 from 2009/2/2
    2) The password for VNC connections can be set under the "settings" tab in the VNCServer programme itself.
  • »08.09.11 - 15:17
    jimh54
    Thanks
    [ Edited by jimh54 08.09.2011 - 12:38 ]
  • »08.09.11 - 16:11
    Ruud
    @jimh54
    That's funny, works here. Copy/Paste from my shell:
    New Shell process 6
    Ram Disk:> ifconfig
    lo0: flags=c9<UP,LOOPBACK,RUNNING,NOARP> MTU=16436
    inet 127.0.0.1 netmask ff000000
    Hardware type: Loopback
    eth0: flags=4863<UP,BROADCAST,NOTRAILERS,RUNNING,SIMPLEX,SANA> MTU=1500
    inet 192.168.1.66 netmask ffffff00 broadcast 192.168.1.255
    Hardware type: Ethernet, address: 0:14:51:17:76:de
    Use "ifconfig -h" for usage.
    Ram Disk:>
    You could always specify a static ip under Settings->System->Network.
  • »08.09.11 - 16:18
    jimh54
    I was typing it wrong. I was using iPconfig, not ifConfig. I got the ip address but cannot connect using macbook pro "Chicken of the Sea". have the VNC app password set. It simply times out. i'll try on a windows machine to try to narrow it down.
  • »08.09.11 - 16:52
