re: Pack Ultimate 1.6.4
    jimh54
    Posts: 10 from 2011/8/28
    I just installed this to get E-AUE primarily. Fantastic work, this package. I have a small issue though, that I hope someone here can help me solve. When I execute the E-aue Gui program, I get a dialog that says I need arexxsyslib.library installed. I thought MorphOS had arexx installed by default but later found out this is not so. I have tried to find arexx through a google search but can only find other packages that are replacements for arexx. Will one of them supply the necessary file? If not, where can I find thhe original arexx install package or the file and where would I put it?
    Thanks
  • »07.09.11 - 14:52
    Posts: 12572 from 2003/5/22
    > I get a dialog that says I need arexxsyslib.library installed. [...]
    > where can I find [...] the file
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7935&forum=9&start=15
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7935&forum=9&start=12
  • »07.09.11 - 15:10
    jimh54
    Mr. Wolf,
    The link to aminet works but there is no file found matching arexxsyslib.library. try it and if you can find it I'd be most grateful. any other suggestions? Do you think Brexx would supply the necessary file?
    [ Edited by jimh54 07.09.2011 - 12:51 ]
  • »07.09.11 - 16:30
    Ruud
    Posts: 335 from 2009/2/2
    @jimh54
    Try this one:
    remotecli
    It's a small package with rexxsyslib.library included.
  • »07.09.11 - 16:56
    Correct. But there are 23 packages found matching rexxsyslib.library, which is the library you want.
    No.
  • »07.09.11 - 18:39
    jimh54
    Thanks RUDD That did the trick.
  • »07.09.11 - 22:26
