Dual Core 1Ghz MorphPAD Tablet + MorphOS-Mobile!
Topic is Locked
  • Visitor
  • Acill,
    What the hell is this all about? Im lost here. These things a pure junk.
    http://www.acill.com
    No wonder your lost.......
    Look at your signature:)
    [ Edited by amber-inc 18.08.2011 - 05:17 ]
  • »18.08.11 - 02:16
  • Visitor
  • Andreas_Wolf,
    "Dual core efika" with a single core chip? You really lost me here.
    What i meant was an Tablet Computer called MorphPAD what had a dual core cpu regardless of wether MOS can utilise the secondary core.
    The Dual core CPU's clock at a higher rate of 1.7ghz
    while the single core version is highest 1.3ghz
    Either way single or dual core the Dual Core one is better:)
    I just dont know why everybody seems so lost....
    Regards.
  • »18.08.11 - 02:22
    Simon
    Posts: 809 from 2008/7/6
    maybe because it's all useless blahblah ?
  • »18.08.11 - 06:27
    Posts: 12572 from 2003/5/22
    > Yes a 603e core basically G3 and G4 compatible:)
    What's that referring to?
    > e600 is perfect:)
    As I said, not for tablet use I'm afraid.
    > the fastest e300 can be clocked to 667mhz actually in single core configuration.
    No. As I said it's 800 MHz. Check the MPC8377E, MPC8378E and MPC8379E. And as I said, all e300 core based chips are single-core.
    > I only talked about a dual core chip before you told me about MorphOS leaving
    > secondary core idle:)
    I told you about MorphOS ignoring further cores in posting #3. You coined your "dual core efika" phrase only in posting #15. Care to explain how posting #15 is before posting #3?
    > The e300 is a nice chip:)
    The e300 is no chip at all, just a core. If you want e300 you'd have to decide for a chip incorporating this core, that means choosing from either MobileGT range of chips (400 MHz max) or PowerQUICC II Pro range of chips (800 MHz max).
    > at 667Mhz single core:) "it will do"
    667 MHz e300 would mean dismissing MobileGT for PowerQUICC II Pro anyway. So why not just go for 800 MHz?
    > we wann look at the "e600" its better
    Better performing than e300, yes, but also consuming more power. Too much for a tablet if you ask me.
    > and can be clocked at 1.7ghz in dual config or upto 1.3ghz in single core config.
    No, maximum clock frequency (without overclocking) for e600 based chips is 1.5 GHz as dual-core SoC (MPC8641D), 1.7 GHz as discrete single-core (MPC7448) and 1.5 GHz as single-core SoC (MPC8641).
    > Which ever way it works the e600 is better:)
    I very much doubt its suitability for a tablet. Btw, when did your plan change from importing pre-built ARM Cortex-A9 based tablets to developing your own PPC based tablet?
  • »18.08.11 - 08:44
    Yes, that's what I've understood. And that's also exactly why I don't understand that to my question what dual-core chips you have in mind for that you reply with e300 core (which does not exist in a dual-core configuration) and single-core chips based on e600.
    > The Dual core CPU's clock at a higher rate of 1.7ghz while the single core version
    > is highest 1.3ghz
    No, that's not true. See previous posting.
    Not for MorphOS.
    It could be because you're constantly switching your points, from wanting to use pre-built devices to developing your own device, from ARM to PPC, from dual-core to single-core to dual-core...
    I advise you to make up your mind in terms of what it actually is you want to *do* (not just talk about), how you're going to achieve this (business plan) and only then make a serious business proposition to the MorphOS Team.
  • »18.08.11 - 09:11
    SoundSquare
    Posts: 1214 from 2004/12/1
    I guess the MorphOS team already has a prebuilt answer to pot smokers business plans.
  • »18.08.11 - 11:35
    boot_wb
    Posts: 874 from 2007/4/9
    There's a business plan?
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »18.08.11 - 12:01
Topic is Locked
