Wireless printer connected to MorphOS?
    osco
    Posts: 680 from 2009/10/20
    Can MorphOS send a print job to the wireless printer? It's a mini connected ethernet to the router?
     :-D
  • »11.07.11 - 02:04
    boot_wb
    Posts: 874 from 2007/4/9
    Hi Osco,
    It depends upon the protocol used by the printer.
    Check out Geit's Netprinter.device - it's in the contributions folder on the MorphOS iso iirc.
    [ Edited by boot_wb 11.07.2011 - 09:23 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »11.07.11 - 06:23
    analogkid
    Posts: 719 from 2004/11/3
    And make sure you have a supported printer, best case is a Postscript/PCL compatible printer.
  • »11.07.11 - 07:53
