Posts: 2095 from 2003/6/4
Have you changed the filesystem with HD Config before formatting? I suggest to use the same filesystem as your internal hdd.
If you decide generally for a rdb disk layout keep in mind, that rdb disks are not readable with Win (or are there tools for that available?).
