version command behaviour...
    ausPPC
    Posts: 543 from 2007/8/6
    Maybe I'm the only person who didn't know but it seems weird to me...
    The version command in MorphOS 2.7 stops printing the version string after it encounters the end of the second numerical sequence.
    So, a version string like this -
    $VER: SuperProgram v1 created on this sunny 26th day of May 2011
    gets output as -
    What gives?
  • »26.05.11 - 03:22
    CISC
    Posts: 619 from 2005/8/27
    It's a "feature", $VER: strings are supposed to have a strict formatting, ie; "$VER: ProgramName Ver.Rev", then anything following that is considered extraneous information.
    Your $VER: string is far from this formatting, and thus reveals the shortcut the Version command uses enforcing this formatting... ;)
    - CISC
  • »26.05.11 - 04:38
    Piru
    Posts: 608 from 2003/2/24
    This applies to MorphOS version strings as well:
    http://openamiga.org/?function=viewpage&pageid=16
    (There are some slight differences, for example the leading \0 isn't strictly required, but is of course allowed)
    [ Edited by Piru 26.05.2011 - 19:21 ]
  • »26.05.11 - 14:19
    ausPPC
    Thanks for that. I've just been playing around with a text file and using a binary editor to put in the leading and trailing zeros. The openamiga.org reference mentions version strings with dates and a comment after the version and revision numbers. Given what CISC said, I guess that it's intended that the date and comment are not displayed?
  • »26.05.11 - 17:35
    ausPPC
    That's interesting (at least to me)...
    This string -
    \0 $VER: SuperProgram 1.1 (11.11.1111) comment!\0
    gets displayed as -
    SuperProgram 1.1
    But this string -
    \0 $VER: SuperProgram v1.1 (11.11.1111) comment!\0
    gets displayed as -
  • »26.05.11 - 17:45
    Piru
    They are displayed if you use FULL/S option.
  • »26.05.11 - 18:43
    Piru
    This string -
    gets displayed as -
    SuperProgram 1.1
    The date is bogus there (earliest valid amiga date is 1.1.1978), but otherwise it's ok. Use FULL/S to see the full thing.
    But this string -
    gets displayed as -
    Don't do that. Do not add any extra characters before the version number.
    [ Edited by Piru 26.05.2011 - 23:47 ]
  • »26.05.11 - 18:44
