Posts: 680 from 2009/10/20
http://support.apple.com/kb/TS3742
I have a dual boot system with Morph OS the default boot...he morph side is fine but dual booting to the Mac side produces
the image from the link....
Have any had this bug/ is there a keyboerd fix?
Mounting from the TOOLS shows the X side. dirs files apps etc....
Thanks in advance
