MorphOS Developer
Posts: 610 from 2003/2/24
Hmm, inside the boot.img; Is this something you guys are targeting to a MorphOS 2.8 release already, or will it come in 2.9?
Honestly I'm not sure yet. I'd guess it depends on if the source can be brought to PFS 5.3 level (I think it's very close already, except for PFSdoctor) and the remaining bugs fixed (I get the "Beta warning requester #1" with the 68k PFS3 5.3 while the bug is supposedly fixed!). Also, I'd very much like to see the PFS3 softlink support improved (it doesn't work very well with ixemul and relative softlinks, making GG environment on PFS3 partition slightly painful to use).
Of course there also is the current 100GiB partition limit which kind of sucks as well. There are some ideas on how to raise this limit, but I think all those result in incompatible filesystem... As you can see there are a lot of things to consider.
