Dual boot on Mac mini AFTER Morphos installed
    Qwert44
    Posts: 22 from 2009/11/16
    Dear All,
    I would like to ask for the easiest method how to install Mac OS X on a Mac Mini, that has a full disk MorphOS installation already (without deleting the MorphOS part, just reducing).
    The installation guide I have found does not detail it, only the other way around: keeping Mac OS X and then install MorphOS, but I need the opposite,
    many thanks
    Qwert44
  • »29.03.11 - 09:14
    Posts: 3275 from 2003/3/5
    There's no "proper" way to do this right, really. I suggest you backup your data and do a full reformat.
    Alternatively, you could: 1) defragment the data partition (assuming this is the last one on the hdd), 2) resize the data partition using HDConfig and create a hfs+ partition to cover the gained space (be extra cautious here, the partition must stay larger than the amount of data you had on it!, I'd say 20% is a safe margin), 3) save the new layout and reboot, 4) launch SFSDoctor and repair the data partition, 5) install OSX on the new partition, do NOT attempt partitioning on OSX!
  • »29.03.11 - 09:58
    And don't come back whining if you lose your data because you decided to ignore backing it up :)
  • »29.03.11 - 09:59
    Qwert44
    Okay, thanks a lot, I give a try (with backing up :) )...
  • »02.04.11 - 18:14
    Let us know how you make out.
  • »03.04.11 - 01:44
