Yes, I did get answers to all my questions. Check out the thread now.
http://eab.abime.net/showthread.php?p=744622#post744622
The 060 that Jakub is using will be at or above 100MHz, due the revision 6 chip he is using.
I am not sure what revision 68060RC50 I have, so I don't know if mine will overclock that high without instability problems and over heating.
MikeJ confirmed that the daughter card will be available without the 68060 installed, so you can solder your own 060 to the board. (or install an 060 socket, so you can swap 060 chips in the future)
[ Edited by amigadave on 2011/3/23 16:49 ]
