MD5 in MorphOS
    Posts: 2732 from 2003/2/24
    Just a short question; is things like date and time stamps included when MD5 is calculated in MorphOS (like in the Ambient info-window for a file), or is it just the binaries of the actual file?
  • »02.03.11 - 09:18
    Posts: 12570 from 2003/5/22
    The latter.
  • »02.03.11 - 09:37
    MarK
    Posts: 641 from 2004/1/25
    must be only the actual file data, otherwise you wouldn't be able to check the md5sum with copied files...
    bye, MarK.
  • »02.03.11 - 09:37
    Yes that makes sense of course, and it's the very purpose of MD5 in the first place. Thanks! :-)
  • »02.03.11 - 12:24
