output window close?
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    I'm pretty well sure i'm missing something here, i've setup OWB to play mp4 in mplayer. but everytime the video opens it displays a owb output window. what command can I use to stop this window opening?
    current Action:
    System:Applications/Mplayer/GMPLAYER %l
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »19.01.11 - 18:12
    Tcheko
    Posts: 540 from 2003/2/25
    current Action:
    run <>nil: GMPlayer %whatever
  • »19.01.11 - 18:27
  • TGR
    TGR
    Thank you Tcheko that did the trick.
  • »19.01.11 - 18:48
    @TGR,
    Time to update your signature, or your version of MorphOS. (2.4?)
  • »20.01.11 - 03:22
  • TGR
    TGR
    It is indeed time to update the sig :) , still not on 2.7 yet. Really should start using morphos alot more .
  • »20.01.11 - 11:27
    Posts: 423 from 2005/4/9
    similar question:
    how to make ambient shell output window autoclose? for example if i extract an lha the an output shell window will open with progres which is fine but i have to close it every time by hand. i know it has to do with some auto|close argument but couldnt make it work yet. anyone could help pls?:)
    right now this is command from the ambient mime prefs regarding lha:
    lha -I x %sp `requestfile DRAWERSONLY TITLE "Kicsomagolás ide..."`
    zx.spectrum@3.5
  • »20.01.11 - 21:44
  • mk
    mk
    Posts: 72 from 2004/5/24
    > ambient shell output window:
    - Ambient Menu: Prefs/Ambient
    - Window: Console
    - Line Window:
    CON:0/20/800/300/Ambient Output Window/AUTO/CLOSE/WAIT
    If you remove "/WAIT" then window closed immediately after output.
    [ Edited by mk on 2011/1/21 1:44 ]
  • »20.01.11 - 22:39
    Tcheko
    You're welcome. Case solved. :)
  • »20.01.11 - 22:52
    mk: thx!!
    zx.spectrum@3.5
  • »21.01.11 - 15:50
