Proof of concept teaser seen on AmigaWorld.net before here??
    Posts: 649 from 2004/4/15
    Krashan wrote:
    I'm not sure if Gallium drivers for cards currently supported by MorphOS have better performance than MorphOS native ones.
    [ Edited by Krashan on 2011/1/1 19:32 ]
    Gallium and MorphOs drivers do not intersect at the moment,
    but Gallium should be more complete (hardware and openGl features).
    IMHO gallium will grow very fast, because there is more than
    one person who works on it.
  • »01.01.11 - 17:51
    Posts: 12539 from 2003/5/22
    Gallium3D is R300+ (and NV30+) only.
  • »01.01.11 - 19:05
    For the moment.
  • »01.01.11 - 19:27
    > For the moment.
    You mean there're plans to support GPUs older than R300 or NV30 in Gallium3D?
  • »01.01.11 - 21:25
    > For the moment.
    Not older, but newer. I did not say that development of special MorphOs divers for
    old chipsets should stop. But for newer graphic cores, MorphOS Devs should think
    about, if they can beat gallium in future. It would be much better to work together
    with developers of gallium and the red ones, who are already using gallium.
  • »02.01.11 - 08:32
    Then your answer twofoldly doesn't make sense. Gallium3D already supports up to R800 and NV50 right now. That's what I wrote: "R300+" and "NV30+", which means "R300 and newer" and "NV30 and newer".
    > for newer graphic cores, MorphOS Devs should think about, if they
    Yes, that's what I proposed to pega-1 5 months ago (German):
    http://www.pegasosforum.de/viewtopic.php?p=44947#44947
    I don't think they're using Gallium3D yet.
  • »02.01.11 - 08:57
