If the worst happens...
    insurgent
    Posts: 64 from 2007/7/8
    Hypothetical question:
    Let's say your MOS desktop is the main (or only) system that you use. If the hardware - other than hard drive - fails and you don't have replacement parts or another MOS installation, how would you salvage all of your content from the HDD? I'm assuming you can get access to another Windows/Linux/MacOSX machine.
    Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
    Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
    Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
    Dell UltraSharp 2407WFP 1920x1200
    PowerBook G4 ready :-)
  • »07.12.10 - 08:36
    jcmarcos
    Posts: 1178 from 2003/3/13
    Perhaps you could make thar other computer to read MorphOS hard drive, if you can make it understand MorphOS' filesystem.
    But MorphOS is so small you could make a full backup of it daily, to a small external device. Remenber that old "copy all clone" install procedure, when MorhpOS didn't have its setup wizard?
    If the backup volume uses the popular FAT32 filesystem, you'll loose the file protection bits, which it's not a disaster, but it's a pain. Hint: In the MorphOS CD there's a little script to set those protection bits, as the files effecively come from a CD, which filesystem also doesn't have protection bits.
  • »07.12.10 - 08:52
    Posts: 1099 from 2004/9/23
    What do you to when the one and only windows system dies?
    I guess you would get a relacement system. Problem solved.
    Unless you give up your MorphOS hobby forever, you simply pick up a new Mac or other compatible MorphOS hardware and start over.
    If you take the broken hardware as a sign to give up your hobby just get your drive to someone with a proper Mac or MorphOS compatible system and copy the data. Since its only music, movies and texts you won´t get any trouble, here.
    And, even more important. There is always your backup, which allows you to install from scratch back to your privious system.
    I currently use a simple tar/gzip script to backup my system drawer wise to a network drive. Flags are bad, but as already said. There is a script for system files and most other stuff can be fixed by a simple "protect s:#? s add".
    So, no big deal!
    Geit
    [ Edited by geit on 2010/12/7 12:01 ]
  • »07.12.10 - 08:58
    Posts: 12570 from 2003/5/22
    I don't think that "all of your content from the HDD" only refers to MorphOS system files.
    ...and the filenotes.
  • »07.12.10 - 09:16
    jcmarcos
    What about the executable protection bit, to be set in "C:#?" files at least? I thought it was mandatory...
  • »07.12.10 - 09:31
    insurgent
    @geit:
    Good point that it makes no difference - it's about doing same in MOS as one would with any
    other platform.
    @others:
    There are some good guides on this forum about backups already. So, to preserve all file metadata there are limitations to file systems one can use for backup e.g. SFS, IceFS, etc. If that was your only backup, could you mount that file system in another OS?
  • »07.12.10 - 09:32
    MarK
    Posts: 641 from 2004/1/25
    you can always have a backup hardware... a spare efika could do the trick for you...
    bye, MarK.
  • »07.12.10 - 10:22
    XzIt
    Posts: 250 from 2005/1/19
    I just setup more then one hdd and use primary as System disk and allways backup what i have on my system disk to diffrent drive.
    i do this evertime i update my Morphos istallation and i dont have a partion thats bigger then must have form system, like 5gig or soo.
    btw, i dont use the system disk to store my apps either. :D
    X
  • »07.12.10 - 14:22
    mfilos
    Posts: 2 from 2008/7/31
    I always found the usage of LHA the best backup ever :)
    Just go to a CLI and use (assuming for example that your Partition you wanna backup is DH0:)
    1> DH0:
    1> lha -aezrx a TARGET:Backup.lha #?
    TARGET can be any other Partition, NFS Drive, USB Stick etc...
    That command will LHA everything from drive DH0 into an Backup.lha file maintaining all protection bits. If you also want the file compressed you can use the "Z" option instead of "z" in the declaration of the command.
    System backup is the important part. For games etc, you can take a backup not so often. I guess if you have an MP3/Video collection on MorphOS, you can have these backed up in an external HD anywayz :)
    [ Edited by mfilos on 2010/12/24 8:28 ]
    A1200D PPC: 060@60/603e+@330,256MB,ACard+16GB CF,Idefix Express+4GB CF+DVD-RW,BVision,Indivision AGA,Ratte's AutoSwitch,Clockport Expander,Subway,WiFi,Cocolino,PicoPSU
    Mac mini: G4@1.42GHz,1GB,60GB,MOS 2.7(registered)
  • »24.12.10 - 04:28
    cecilia
    Posts: 459 from 2003/8/30
    come on, people, this is 2010, almost 2011. burn data DVD's, get a portable USB Hard Drive, flash drives, and so on. Amiga Forever lets you read amiga drives.......always backup your data.
    Merry Christmas and Happy Festivas
  • »24.12.10 - 21:47
    I've got a replacement motherboard, spare hard drives, and a USB backup drive. I'm all set (wouldn't mind an extra power supply though).
  • »24.12.10 - 22:46
