I can't reach Morphzone ... a lot.
    Simon
    Posts: 809 from 2008/7/6
    For some reason a lot of times I can not get to Morphzone, especially the last few days it just wasn't there . Is it just happening to me or what is going on ?
  • »17.12.10 - 15:50
    amyren
    Posts: 219 from 2010/5/15
    I havent had any problems with this during the last few days.
    Either you have been unlucky and its been down just the times you tried, and I have been lucky every time... Or it could be something with your network.
  • »17.12.10 - 16:34
    Simon
    I had it at home and I had it at work ...
  • »17.12.10 - 16:56
    xyphoid
    Posts: 870 from 2008/7/11
    me too it said maintenance
  • »17.12.10 - 17:00
    Simon
    Maintenance ? I just got an error like there was nothing on the server.
  • »17.12.10 - 17:26
    ausPPC
    Posts: 543 from 2007/8/6
    I had morphzone access trouble some time ago which I think was resolved by entering morph.zone instead of just morph.zone - I'd been using the latter with Opera's speed-dial so it took me a while to catch this little snafu...
  • »17.12.10 - 18:33
  • ASiegel
    Posts: 1397 from 2003/2/15
    There was a non-obvious conflict between the remote domain and the local server configuration. As a result, "https://morph.zone" did not work properly. (But then again, some modern browsers add "www" automatically in case an entered URL seems to point nowhere.)
    Anyway, the issue should be fixed now.
  • »17.12.10 - 19:16
    pampers
    Posts: 1068 from 2009/2/26
    It's only about configuring domain on the server. I was saying that in recent topic but with no response ;)
    MorphOS 3.x
  • »17.12.10 - 20:00
  • ASiegel
    @ pampers
    Actually, the local server configuration has remained unchanged. The Apache settings were flawless. The issue was with remote domain settings handled by a web interface ("*" vs. "@").
  • »17.12.10 - 20:23
    koan
    Posts: 303 from 2005/11/21
    In the last few weeks I have occasionally had a "null" response when visiting this site. I always use https://morph.zone
  • »17.12.10 - 21:55
    Yes, I had the same thing happen briefly today, but obviously it resolved itself.
  • »18.12.10 - 00:11
