Morphos 2.7 has been relased
    Posts: 3336 from 2003/3/5
    You're safe as long as MorphOS doesn't use the 2nd CPU - if it ever does: bye bye NAP mode. NAP can only work reliably with 1 CPU (and Apple actually doesn't use NAP on 2 CPU Power Macs as well).
  • »03.12.10 - 04:06
  • rms
    rms
    Posts: 606 from 2004/11/27
    Hi, I noticed that there is an Urltext.mcc and Urltext.mcp but I can't see an entrance in MUI settings for that. Normal? or did I miss something?
  • »03.12.10 - 10:54
    Lizard
    Posts: 34 from 2004/4/27
    Yup, you missed something.
    From the releasenotes:
    Classes/MUI/Hyperlink.#? [NEW]
    A new MUI custom class for user-configurable URI objects.
    [list]Supports all URI schemes supported by the OpenURL system.[/list]
    [list]Handles additional URI schemes (amigados:, workbench:, etc.)[/list]
    [list]Includes a wrapper for obsolete legacy class 'Urltext.mcc'[/list]
  • »03.12.10 - 11:06
    boot_wb
    Posts: 874 from 2007/4/9
    @Jacadcaps
    Thanks for the info :-)
    I guess it's a relatively simple chip register setting, rather than the seed of a greater "MorphOS Power Management" project then?
    Rich
    [ Edited by boot_wb on 2010/12/3 13:12 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »03.12.10 - 11:12
    Travis_H
    Posts: 166 from 2009/12/17
    I updated my 2.5 MacMini installation tonight and it didn't work. I boots to about the part when the bootpic should display (blue butterfly), then just quits. I tried a second update with the same results. I copied back the 2.5 MorphOS directory and it boots up just fine but now indicates I have 2.7 installed! I'm just waiting for the other shoe to drop.
    TJH
  • »04.12.10 - 05:17
  • rms
    rms
    @ Lizard
    I still do not understand, sorry. Shouldn't I have an entrance in MUI settings, where I can change prefs, like with Lamp, or PowerTerm or any other?
  • »04.12.10 - 06:16
    Jambalah
    Posts: 820 from 2008/3/30
    @RMS:
    I tried to scan other classes in General MUI prefs and I found UrlText settings. But all I could do is read this message:
    Urltext is obsolete. Any urltext.mcc or urltext-mcp in SYS:Classes/MUI can be safely deleted.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »04.12.10 - 07:10
    Posts: 2581 from 2003/2/24
    @Travis_H
    The 2.7 indicates that you have successfully installed the 2.7 boot.img onto your boot-partition, everything else is probraly still 2.5.
    When you had the full 2.7 installed, how did it "quit" ? Unresponsive ? Something on the screen ? Instant reboot ?
    Did you try to access the earl-startup-menu ? And if so what happens on boot with out startup-sequence ?
    [ Edited by Kronos on 2010/12/4 10:38 ]
  • »04.12.10 - 07:37
    eastone
    Posts: 47 from 2007/8/4
    MDD 1.25 Ghz 2003: audio still does not work correctly, the same how it was in 2.6 :(
    It is mean that i can hear sound from internal speaker and external set (2+1) but from both sources is to quiet.
    Sorry for my bad english.
    eastone
    [ Edited by eastone on 2010/12/4 14:02 ]
  • »04.12.10 - 10:53
    Drako^lM
    Posts: 144 from 2005/8/10
    use SB Live or Audigi ;)
    Hardware :
    Power Mac G5 2.3 Ghz & MorphOS 3.18 & OSX 10.5
    Mini G4 1.5 Ghz & MorphOS 3.18
    BlaBla Team Member -> http://blabla.ppa.pl
    AmiParty Team Member -> http://www.chal.pl/
  • »04.12.10 - 11:12
  • rms
    rms
    @ Jambalah
    That's exactly what I tried to explain, I deleted the old URLText.mcc and URLText.mcc in
    System:classes/MUI so that only the ones are left in MorphOS/classes/MUI, but now here
    there isn't any entrance for URLText in General MUI prefs. So I wanted to know why.
  • »04.12.10 - 13:21
    Travis_H
    My MacMini never got to the Ambient screen. It looks like it gets to about the part when a bootpic (the blue butterfly) should be displayed, then the hard drive eventually stops. It doesn't look like a crash or hang, it just stops. Unfortunately, it doesn't go further, so I can't see at what point it has stopped. It responds to Option-Apple-Apple for reboot.
    I did no other diagnositics (because I wasn't sure what to do), so I rebooted with the CD-Rom, copied back my MorphOS directory and re-booted thinking I would be back to 2.5.
    Travis
  • »04.12.10 - 14:03
    xyphoid
    Posts: 870 from 2008/7/11
    Placing a blank cd in a external usb drive still freezes the system! Why is this not important enough to fix? you can't dub, or copy to external usb drive, (though it reads data fine) If your internal drive goes, then forget about burning anything! This has now been an issue since 2.2 :-?
  • »04.12.10 - 14:08
    Posts: 12570 from 2003/5/22
    Because you now have to use the Hyperlink class prefs. That's what Lizard wanted to tell you.
  • »04.12.10 - 18:08
    DrZarkov
    Posts: 142 from 2004/3/21
    I've just installed the update. Everything is working fine, nothing is missing. How boring.  :-D
  • »05.12.10 - 12:28
  • rms
    rms
    @ Andreas_Wolf
    so if I understood that correctly, I do delete the Urltext.mcc and Urltext.mcp in System:Classes/ so that there are only the ones in MorphOS/Classes/ left.
  • »06.12.10 - 04:15
    Tcheko
    Posts: 544 from 2003/2/25
    rms wrote:
    @ Andreas_Wolf
    That's it. :)
  • »06.12.10 - 04:46
