IRC client: top 5 features
    Tcheko
    Posts: 544 from 2003/2/25
    I started some weeks ago to develop an irc client which is currently in a quite usable state (I only connect with it now on freenode #morphos for ex.)
    Currently, it has custom rendered chat with configurable colors/font, copy/paste, network threaded, multiple server handling, last read line ala xchat and some other nice features.
    I'd like to get some insight about what features are a must have for you.
    Thanks for your advice.
    Tcheko
    [ Edited by Tcheko on 2010/11/11 20:24 ]
  • »11.11.10 - 14:24
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    ok.
    my top 5:
    - Arexx Port
    - private chats (DCC)
    - file transfer
    - chat logging
    - input history (cursor up/down for previous/next test, like in AmigaShell)
  • »11.11.10 - 15:14
    Simon
    Posts: 809 from 2008/7/6
    What can it add compared to AMIRC ? Or what does AMIRC not have ? Don't get me wrong, it's an honest question... I just know how the get to the morphos channel, but that's more or less all I know about IRC. AMIRC seems to have a lot of options and I heard about wookiechat (that I never used ) ...
  • »11.11.10 - 16:15
    pampers
    Posts: 1071 from 2009/2/26
    AMIRC doesn't have option to buy a key anymore ;)
    Tcheko: basic AMIRC options would be nice.
    I don't know why but I cannot get used to WookieChat.
    MorphOS 3.x
  • »11.11.10 - 16:47
    Tcheko
    @Oepabakkes:
    Diversity? A new software that is actively supported/developed? Something that implements latest protocol natively (like SDCC & UTF8 for ex.)?
    Some points for a new client:
    - WookieChat is no more supported for MorphOS and uses external MUI classes that need to be installed. Not a big deal but some of these classes are known for stability issues. Also, W.C. outputs lot of debug about group rendering problem.
    - AmIRC, full featured (bloated?) client. No more supported/developed. It needs external script to handle UTF8 charset for example. It stills need a key to work more than 30 minutes and such key isn't available for purchase anymore. No multiple server support. you need to launch mulriple instance of it.
  • »11.11.10 - 16:55
    Krashan
    Posts: 1107 from 2003/6/11
    Support for character set transcoding, like charset.plugin for AmIRC.
  • »11.11.10 - 17:11
    Simon
    I can only agree with the way you explain it...
    But there is a way to get a key for amirc: http://amigakit.leamancomputing.com/catalog/product_info.php?products_id=543
    Altough pretty expensive to my opinion, it gives you a valid key for AMIRC.
  • »11.11.10 - 17:36
    Tcheko
    AmIRC is still a dead software no more supported/developed even if you can purchase a bundled key in a software package. Anyway, good point. Didn't know about this.
  • »11.11.10 - 17:43
    Simon
    Well to be honest I tought IRC was something old in general that didn't really need up-to-date client. I actually never used it untill I started using MorphOS  8-D
  • »11.11.10 - 17:49
    hooligan
    Posts: 1948 from 2003/2/23
    <xxx> slaps <xxx> with a large trout-feature
  • »11.11.10 - 22:22
    Debaser
    Posts: 161 from 2005/7/12
    I have been eagerly awaiting this Tcheko. :) Thank you!
    I think you have most of my needs covered.
    +1 on:
    Chat Logging, DCC pvt chats, and file transfers.
  • »11.11.10 - 23:43
    weiseb
    Posts: 215 from 2003/3/29
    What I am missing in AmIRC is SSL and /dccserver support
    http://www.mail-archive.com/irssi-dev@dragoncat.net/msg00623.html
  • »12.11.10 - 07:06
    Jupp3
    Posts: 1193 from 2003/2/24
    Why would you want to slap yourself with a large trout? ;-)
  • »12.11.10 - 10:25
    manga
    Posts: 41 from 2009/5/6
    ssl support and some kind of plugin engine to support for example blowfish encryption would be very nice :)
    Powermac MDD 1,25GHz Radeon 9000 Pro 128MB, 1,5gb, Terratec Aureon Space, USB2.0 NEC, MorphOS 2.6 regged, Powermac MDD Dual1.42, Radeon X800XT PE 256MB waiting for r300 support, Mac Mini 1.5GHz MorphOS 2.6 Regged, Efika Radeon 9250 128MB Morphos 2.6
  • »12.11.10 - 19:53
    Tcheko
    Thanks @all for advices.
  • »14.11.10 - 05:47
    March
    Posts: 91 from 2003/7/30
    A few more words about charset transcoding: make sure it will be possible to set/change charset per each chat window (or at least server). Some servers and channgels use utf8, but some still the old iso-8859-x encodings.
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »14.11.10 - 06:14
    Tcheko
    Servers don't really care about charset encoding. They usually just send the string received as is. Charset encoding is more a matter of the client side and IRC protocol has absolutely no provision for charset signaling. I read that some servers do some on the fly charset conversion. I will add some charset encoding per chat window/server.
    At least, i could implement some heuristics to detect charset encoding. This is a real impressise process with random results but could at least improve somewhat the situation.
    As the charset is matter of the client, I could add as well some charset context menu entry in the nickname list to set correct encoding if any problem occurs with a client.
    Thanks for submit.
  • »14.11.10 - 08:03
    kolla
    Posts: 106 from 2003/4/22
    Everything in one window, like konversation
    -- kolla
  • »14.11.10 - 11:32
    trotter
    Posts: 106 from 2010/1/14
    I cannot get the netconnect3 keyfile to work with AmIRC (under MOS2.6) so I am not sure if you can buy it for the Morphos version. I expect it will work for the 68k version though which according to the morphos readme has some bugs. :(
    Martin
    Running MorphOS v3.18 on Mac mini 1.5GHz 64meg VRAM,1gig ram.
    Palm T3 pda along with pixel 4a GrapheneOS smartphone. Updated August 2023
  • »14.11.10 - 21:53
    Posts: 12570 from 2003/5/22
    http://www.vapor.com/nc3update/index.php
    http://www.ann.lu/comments2.cgi?view=1009452599&category=forum
    http://www.amiga-news.de/en/news/AN-2002-04-00029-EN.html
    http://www.amiga.org/forums/showthread.php?t=2627
    http://eab.abime.net/showthread.php?t=39405
    Not so much to do with PPC or 68k.
  • »15.11.10 - 01:01
    trotter
    I have looked for a couple of hours for my netconnect cd but i cant find it. I dont know where most of my amiga stuff is since i went windows 6 years ago and now I am just returned to amiga.
    I suppose there is no way to extract the serial from my a4000 install?
    Martin
  • »15.11.10 - 12:55
    According to some messages in the English Amiga Board thread I linked to, the keyfile conversion process doesn't work anymore anyway.
  • »15.11.10 - 13:03
    trotter
    ok thanks looks like we are stuck with 30 minutes of AmIRC then :(
    Martin
  • »15.11.10 - 13:19
    Ruud
    Posts: 335 from 2009/2/2
    @trotter
    The version of Amirc on the netconnect3 cd does work ok under morphos afair, although it's a little old. If you can't find your cd, let me know your address and i'll send you a replacement.
    @Tcheko
    Looking forward to trying your irc client once it's released :)
    [ Edited by Ruud on 2010/11/15 16:41 ]
  • »15.11.10 - 14:37
    trotter
    Ruud wrote:
    @trotter
    The morphos readme suggests there are bugs with AmIRC 68k on Morphos.
    I do have the config on my a4000 so i can copy it over if i wish I wanted the netconnect cd for the conversion of the key but it seems vapor dont offer that anymore.
    thanks
    Martin
  • »15.11.10 - 14:41
