Sound fix for volume level on MacMini, eMac, & PowerMac?
    Tiki
    Posts: 21 from 2004/10/4
    If you got a SoundBlaster, you have to select emu10k1.
    Tiki
  • »17.10.10 - 13:47
    JuLieN
    Posts: 35 from 2008/4/16
    Ok, I just opened the case and saw no SoundBlaster card (I wrongly assumed that all PowerMac MDD had one)... So I only have the onboard sound chip, hence the AppleI2S driver... Still, the sound is very low, so it doesn't work well (the chime sound works perfectly good and is very loud ;) ).
    So what should I do? Is there a way to fix the sound anyway, or should i buy a Soundblaster Live! ?
    "A good bug is a dead bug" (Don Dailey)
  • »17.10.10 - 13:50
    Tiki
    Buy a SoundBlaster is the easiest and faster way.
    Tiki
  • »17.10.10 - 16:52
    pampers
    Posts: 1061 from 2009/2/26
    I don't know but my sound is quite loud through headphones via mini jack on front panel of my mdd.
    MorphOS 3.x
  • »17.10.10 - 16:56
    Posts: 1084 from 2003/3/24
    I have a MDD and i have the same Soundproblem with OSX everything is fine but in MorphOS the sound output is to low.
  • »18.10.10 - 14:17
    JuLieN
    @Tiki
    Thanks :) I'll do that. Would a Soundblaster Live 5.1 work too (even just in 2.0)? They seem to be more common than the 2.0 ...
    [ Edité par JuLieN le 19/10/2010 0:31 ]
  • »18.10.10 - 19:31
