Morphos 2.6 keyboard issues
    Dreamcast270mhz
    Posts: 152 from 2009/12/8
    Just tried installing it, it doesn't like my keyboard so is there an onscreen keyboard option?
    My Macs:
  • »10.10.10 - 22:04
    Simon
    Posts: 809 from 2008/7/6
    what do you mean with "doesn't like" ? What kind of keyboard do you have ? I use a regular PC USB keyboard for MorhpOS and on for OSX I downloaded a keymap for it so it can be used for both MorphOS and MacOSX
  • »11.10.10 - 03:54
    Dreamcast270mhz
    it won't work with it, I have a Logitech wireless keyboard and an MS wireless mouse, I have been scrambling to find my old USB keyboard, but in the meantime is there an onscreen keyboard option so I can prodeed w/ install?
    My Macs:
  • »11.10.10 - 14:31
    Posts: 649 from 2004/4/15
    No, there is not any onscreen keyboard.
    Should be add indeed.
  • »11.10.10 - 15:14
    Dreamcast270mhz
    I've decieded to get an M7803 keyboard instead of my logitech, which goes crazy some time anyways. Now, to fix my disk drive problems....
    My Macs:
  • »12.10.10 - 22:06
    _ThEcRoW
    Posts: 298 from 2008/10/27
    I'm currently using a logitecg wave keyboard without problems. Previously i had a logitech internet keyboard wireless and the receiver was detected well under morphos and never experienced any issue with it. Even the wireless mouse of the combo worked. I can look for the exact model if you need it. Hope this helps.
  • »15.10.10 - 11:31
    manga
    Posts: 41 from 2009/5/6
    here a logitech mk710 is working without any problems, a cool feature is that the extra keys for volume control are supported. so its possible to mute or control the volume with the keyboard extra keys. ... ill also use a mac A1016 keyboard and mighty mousse with blutooth at mac mini under morphos. the a1016 does not allow to control the sound by teh keyboard, teh mighty mousse doesnt support the scroll wheel under morphos...else everythng is working like it should :)
    Powermac MDD 1,25GHz Radeon 9000 Pro 128MB, 1,5gb, Terratec Aureon Space, USB2.0 NEC, MorphOS 2.6 regged, Powermac MDD Dual1.42, Radeon X800XT PE 256MB waiting for r300 support, Mac Mini 1.5GHz MorphOS 2.6 Regged, Efika Radeon 9250 128MB Morphos 2.6
  • »15.10.10 - 13:57
    Dreamcast270mhz
    I got a mac keyboard, so I'm good now, the install cd allows me to use it fine, but now other issues are cropping up...
    My Macs:
  • »15.10.10 - 14:22
    _ThEcRoW
    Your bluetooth mighty mouse works under morphos???.
  • »15.10.10 - 15:38
    Dreamcast270mhz
    bad post
    [ Edited by Dreamcast270mhz on 2010/10/15 15:12 ]
    My Macs:
  • »15.10.10 - 16:11
