MorphOS cd boot force alt screenmode
    Bifford
    Posts: 283 from 2003/2/24
    Hey all.
    I recently had to buy a new monitor because my old one died. I now have a Ilyama Prolite B2409HDS (hmmm gorgeous monitor!).
    Problem is when I boot the Peg II from the 2.6 cd I get a "Input Not Supported" logo come up presumably because the default screenmode of MOS cd boot is not supported.
    I have no alternative monitor any more but want to upgrade. Is there any way to force MOS boot to go into a larger screenmode that will display??
    Oh, the OF screen displays fine btw
    Many thanks.
    Bifford
    [ Edited by Bifford on 2010/10/14 8:32 ]
    Bifford the Youngest
  • »14.10.10 - 04:31
    Posts: 3275 from 2003/3/5
    The default mode is what your monitor reports via DDC, but it could be that its DDC report is slightly incorrect. You can force MorphOS to boot into a different screenmode - either hold the Ctrl key while booting to force 1024x768 @ 60Hz or open the bootmenu (if your monitor goes off sync, press 'v' to force 640x480 @ 60Hz) and select the mode there.
    [ Edited by jacadcaps on 2010/10/14 11:39 ]
  • »14.10.10 - 06:38
    Bifford
    Wonderful! Thank you Jacadcaps, the CTRL key did the job nicely :)
    I shall make sure to write that on every future MOS CD I burn just in case I hit the same thing in the future! :D
    Long live MOS! (Btw.....I'm sorely tempted to try it on my MAC MDD!!!!! hehehe :)
    Sam / Bifford
  • »14.10.10 - 16:53
