Ambient: unknown exeption
    amyren
    Posts: 219 from 2010/5/15
    I have a Mac Mini with MOS2.5, and I get this error message quite often. Just after a reboot, and I open a few drawers, then the system freeze while scanning location. And a log server window pops up, with the following line:
    Workbench [MOSSYS:Ambient/Ambient] - Unknown exeption
    double clicking on the line, gives a little more info:
    68k exeption in Task 0x22a90f58 <Workbench [MOSSYS:Ambient/Ambient]>
    then in the stacktrace ppc tab there is some more info
    first 4 lines with object - Abox:Module
    then one line - MOSSYS:libs/trance.library
    2 lines with object - Abox:Emulation
    finally one line with object - MOSSYS:Ambient/Ambient
    When this happens I can not cloase any open drawers, or open new ones. Mouse is still moving and the only action I can do is to navigate in the log server window.
    But when trying to save the log results in a file save requestor, and then the log server freeze as well. Rebooting and everything is ok again.
    Any idea what could be causing this would be welcome.
  • »12.06.10 - 06:35
    Posts: 3251 from 2003/3/5
    Posting a full log could help.
    getramdebuglog sys:log.txt
    [ Edited by jacadcaps on 2010/6/12 12:56 ]
  • »12.06.10 - 07:56
    amyren
    Here is the log.
    keylargo_Init: ResBase 0x200ca438 SysBase: 0x20001948
    keylargo_Init: done
    PMac_Init:
    Driver_Init:
    Driver_Init: process std sata boards
    Driver_Init: process custom sata boards
    Driver_Init: process custom ide boards...done
    DRIVER_Init:
    Found MacIO ATA at 80020000 size 00001000 int 67108888
    DRIVER_Create:
    DRIVER_Create: our device owns it now
    DRIVER_Create: Create Driver
    DRIVER_Create: DriverBase 0x200d7a28 created
    DRIVER_InitBoard:
    PMac_Init:
    MacIO_InstallInterrupt@0:
    MacIO_InstallInterrupt@0: IntStack[0] 0x200e39d4
    MacIO_InstallInterrupt@0: IntEmulHandle 0x200e49e4 EmulHandleSize 0xf0
    MacIO_InstallInterrupt@0: ConfigServer TID 0x10000013
    MacIO_InstallInterrupt@0: EmulFunc 0x11007400
    MacIO_InstallInterrupt@0: Emul ATAInt TID 0x10020017
    MacIO_InstallInterrupt@0: done
    DRIVERIO_EVENT: spurious eventmask 0x40000000..no ObjectData
    DRIVERIO_EVENT: IntSignalMask 0x40000000
    DRIVER_Create: Driver Device 0x200d96ac
    LIB_Open from task $200b0048 "? AsyncInit - <ide.device> ?" context failed!
    Open: name = "env:sys/mount.conf", mode = 1005 failed
    UserLibOpen : $VER: muimaster.library 20.6848 (02.06.10) ? 2008 Stefan Stuntz, PPC, MorphOS, DEBUG
    Intuition requester called from ramlib!
    "emu10kx.audio"
    Unable to open 'openpci.library' version 1.
    [OK]
    "emu10kx.audio"
    [OK]
    Brynhildr [Aboutbox.mcc 20.17 (02.06.10)]
    SWFDEC: [SWFDEC] Loading stream: https://mail.google.com/mail/im/chatsound.swf
    SWFDEC: [SWFDEC] Loading stream: https://mail.google.com/mail/im/sound.swf
  • »12.06.10 - 17:13
    Well... the log has to be done after this happened, on the same session.
  • »13.06.10 - 15:49
    amyren
    I was thinking that, but this was the best I could do. After this happen, I can not do so much I'm afraid, since most of the system is not working. As I say, I can not even save the output from the server log.
    I will try again next time it happens, maybe I still an open a shell and get the log saved.
  • »13.06.10 - 17:42
    Condor
    Posts: 100 from 2005/9/1
    From time to time I have same error in Ambient (with Mos 2.4 and now also with 2.5). Most time this error jump on screen when I switch icon/list view with wheel button on mouse. (fast scroll up-down)
    I will try to grab error log.
    MacMini 1.42, Mos2.5 registred
    [ Edited by Condor on 2010/6/14 8:34 ]
  • »14.06.10 - 03:30
