OSX EXPOSE' on MorphOS!
    magnetic
    Posts: 2129 from 2003/3/1
    Morphos Devs
    I have brought this up before but thought i'd make a a thread to see what the user base and everyone thought.
    One of my favorite features of OSX is Expose where you go to the cornere of the screen and all the windows are shown and you can choose a window... Vista has this type of feature to with the 3d layer window view. Can we please get something like this for Morphos? It really makes my computer production much easier..
  • »20.08.10 - 18:26
    Posts: 2217 from 2003/2/24
    I've said this before too, but doesn't rmb over window depth gadget basically do the same thing?
  • »21.08.10 - 04:50
    Tcheko
    Posts: 543 from 2003/2/25
    @jPV, it does but you have to target a depth gadget before.
    This feature has something annoying to me : the targeted window is not listed. Sometime, I search for targeted window and don't find it...
    Having an Expose like commodity that triggers some icontrol settings would be nice imo. Does icontrol have some AREXX port?
  • »21.08.10 - 05:13
    magnetic
    jpv
    Hmm didnt know about RMB on depth gadget. Its nice, and helps but not quite the same as Expose shows all active windows.
  • »21.08.10 - 16:33
    Doesn't RMB on depth gadget also show all windows (on current screen, for screens there's RMB over screen depth gadget)? As far as I can see, it shows all windows except the window it is used from and backdrop windows.
  • »22.08.10 - 05:54
    Posts: 1521 from 2003/2/24
    Isnt Expose patented by Apple?
  • »22.08.10 - 08:40
