Burning A DVD Movie From .avi file
    Posts: 1367 from 2010/1/6
    I remooved copy protection always (or let's say in most cases) with mplayer without any problems. The dumped VOB-file needs no timecorrection anyway....
  • »18.02.10 - 06:18
    xyphoid
    Posts: 870 from 2008/7/11
    Blue hd doesn't incorporate the spumux and mplex features for menus, background and titles. I' m having a hell of a time manually creating the menu and titles!! none of the linux docs tell you how to put this together step by step.
    1 yea I can create a dvd (which plays)
    2 some modern dvd/blueray players want some type of title, and wont play directly ( dvdauthor dvd's)
    3 so I get stuck at both xml files, how to execute the proper spumux and get the dvdauthor xml with appropriate reads for menus
    you need jpg frames, audio and no set steps on how to set everything up step by step
    links I'm working with
    http://radagast.bglug.ca/linux/dvd_authoring/dvd_authoring.html
    http://www.linuxquestions.org/questions/linux-software-2/creating-dvd-menus-with-spumux-dvdauthor-227230/
    http://www.tappin.me.uk/Linux/dvd.html#menus
    Any help guys?
    [ Edited by xyphoid on 2010/6/21 21:44 ]
  • »21.06.10 - 22:38
    Yes, as everyone else has pointed out, it will run MorphOS fine. It's got the right processor and GPU.
    However, you might want to check out Ebay. I've seen better offers there (more memory, lower price, etc).
  • »21.06.10 - 23:25
    xyphoid
    My blue hd acting up. To be honest, I haven't been using it much if at all since 2010/6/21 (last post)as i found it quicker to author manually, but now I have multiple short .avi videos which I'd rather drop into the gui. and go. It now writes the folder,(dvd)with .xml file, but not the .mpg file. I also notice hitches with ffmeg lately, which could be a factor. Anyone else having issues? Any solutions out there.
    ffmeg - ver svn-r20529(built on nov.15 2009)
    blue hd - 12.2.2010
  • »09.08.10 - 21:27
