Completed MorphOS Dual boot with success but will not boot
    osco
    Posts: 680 from 2009/10/20
    When MacOS boots up A red alert saying that the "Boot" has to be reformated.. This is the sixth installation of MAcX and second of Morphos 2.4.. When I try to switch to Morphos I get a gray screen?
     :-x
  • »17.11.09 - 21:47
    osco
    Dual boot works :-)  :-)  :-)  :-)  :-)  :-)  :-)  :-)  :-)
    On Mac screen reads Image(red stop sign with exclamation point): The disk "Boot" was not repaireable by this computer :-?
  • »17.11.09 - 23:39
    osco
    New signature  8-)  8-)  8-)  8-)  8-)  8-)
  • »17.11.09 - 23:43
    CountRaven
    Posts: 566 from 2007/12/10
    Should work now for you as you pointed. But i9n case that your dual boot still fails just start from scratch. Use Disk Utility of Mac OSX to create all needed partitions letting Boot be your first one. In different case MorphOS will not boot.
  • »18.11.09 - 00:44
    Posts: 12454 from 2003/5/22
    Same here. I don't know the cause for that. Simply ignoring that error didn't raise any problems so far.
  • »18.11.09 - 08:31
    Solution from jacadcaps:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7265&forum=3&start=9
  • »03.08.10 - 06:44
