Network Drive
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Is there any easy way to connect to my buffalo linkstation which is obviously connected to a router. Is there a guide or an easy program to do this . thanks ?
    Now proudly a registerd morphos user
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »18.07.10 - 11:54
    Posts: 3336 from 2003/3/5
    FTP? http://amitradecenter.net/download.html
    Samba? http://se.aminet.net/comm/tcp/smbfs.readme
  • »18.07.10 - 15:56
    Rajinder
    Posts: 38 from 2010/3/24
    @JJ
    hi
    i asked these question found this usefull
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7097&forum=9#73141
  • »19.07.10 - 10:14
  • JJ
    JJ
    @ Rajinder
    Thanks for the link worked a treat. First time.
    Only question for you or other people. How can I get this to run the command automatically so the drive is there after boot ?
    I gussed it wouldn't work adding to user-startup as Im guessing network not up by the time this is run, and I was right.
    I know in Genisis and Miami you could get it to run a script or program when the stack connected is this possible in MorphOS?
    Also FTP worked but thats not much good for using as network drive, but thanks for the info
  • »28.07.10 - 08:39
    boot_wb
    Posts: 874 from 2007/4/9
    Hey JJ,
    Just add the script (or a link to the script) to your WBStartup drawer.
    That should allow the network to initialise prior to mounitng the drive (works for me, anyway).
    Regards
    Rich
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »28.07.10 - 09:23
  • JJ
    JJ
    @ boot_wb
    Thanks that was going to be my next test. Does the file have to have a certain extension or does it need to have a project icon or whatever it was back in the day. been a long time since I used AmigaOS for anything serious
  • »28.07.10 - 09:53
    boot_wb
    When you save the script file, it should save with a project icon anyway (depending on your editing application of choice).
    If there is no .info file, just copy an .info file from anywhere else and rename it to be the same as your script filename but with an .info extension (eg if your script file is called 'script1', name the .info file as 'script1.info').
    Once there is an icon, just make sure the script flag is set (select the icon, go to information, ensure 'script' box is ticked).
    It should now mount the shared drive upon startup, appearing as an icon on your desktop. If the shared drive is not switched on when you start your MorphOS machine, then it will simply not be mounted.
    To avoid annoying con window opening, you may want to add the >NIL: option, eg:
    run >nil: STACK=65536 SMBFS workgroup=[your workgroup name] user=[user name] service=//[share host name]/[share path] volume=[whatever name you want it mounted as]
    From memory, it is also important to add the "stack=" arguement, but I'm sure that the readme will have explained this.
    Best Regards
    Rich
  • »28.07.10 - 10:30
  • JJ
    JJ
    Hi Rich
    Thanks. Already running through run > nil: :)
    I not setting stack , im setting cache=500 at beggining. is stack needed ? Seemed to work ok without it
  • »28.07.10 - 10:40
    boot_wb
    Other users have reported problems (freezing, failure to copy large files, etc) with the default stack size.
    Also, in another thread Piru recommends increasing the stack size to 32768: I've never known him advocate anything which sacrifices resources for no reason.
  • »28.07.10 - 10:53
  • JJ
    JJ
    Ok Thanks for the info
    And yes if Piru advises I will follow that advice :)
  • »28.07.10 - 11:00
    Piru
    Posts: 624 from 2003/2/24
    Well at least in this way:
    in user-startup:
    ; BEGIN network-user-startup
    run <>nil: execute s:network-user-startup
    ; END network-user-startup
    Then create s:network-user-startup and have the following in it:
    waitforport NETSTACK L=30 ; wait network stack to appear (max 30 secs)
    if not warn
    wait 2 ; give network some time to settle, if apps still fail, raise the value
    ; *** start whatever stuff you want here ***
    endif
    [ Edited by Piru on 2010/7/28 17:42 ]
  • »28.07.10 - 11:38
    Posts: 1099 from 2004/9/23
    There is a far more easy way.
    Just create the file "s:network-startup" and place the following lines
    ;--- launch network stack
    execute MOSSYS:s/network-startup
    ;--- now run any other network depending tools
    run DETACH MOSSYS:c/Setclockntp
    Thats all. This script sets the system clock on system boot.
    Geit
    [ Edited by geit on 2010/7/28 16:52 ]
  • »28.07.10 - 11:51
    Piru
    Hmm yeah, that should work as well. :-)
  • »28.07.10 - 12:09
    We should place a dummy file for this which gets installed if there is no such file. :)
    Geit
  • »28.07.10 - 12:33
  • JJ
    JJ
    Thanks all for all your suggestions.
  • »28.07.10 - 13:22
