[solved] RegTool and registration name
    Divinity
    Posts: 517 from 2009/9/8
    I'd like to modify the NAME of registration of MorphOS 2.x ... Is It possibile now with last RegTool in MorphOS 2.5 ? if not Will be It possibile in MorphOS 2.6 ?
    thanks
    [ Edited by Divinity on 2010/7/12 23:42 ]
    [ Edited by Divinity on 2010/7/14 23:59 ]
  • »12.07.10 - 19:42
    Posts: 3311 from 2003/3/5
    RegTool cannot be used to edit the data once posted. No changes are planned in this area there.
  • »13.07.10 - 06:21
    Divinity
    @jacadcaps
    hi,
    Is (will be) possible to rename the registered name of the KEY of MorphOS with other tool, way ?
    thanks
  • »13.07.10 - 19:16
    It's not possible to modify an existing key. You could try to come to #morphos and bug Fab to generate a new one for you though.
  • »14.07.10 - 06:29
    Divinity
    @jacadcaps
    Hi, thanks a lot
    I'll make so :-)))))
  • »14.07.10 - 10:58
    Divinity
    @jacadcaps
    Solved by Fabien in about 10 minutes :) incredible, this is the best team O.S. support seen in ages :)
    I'm ready to buy the next KEY MorphOS for PowerMac MDD/firewire 800 :)
    @Fabien
    THANKS a lot !
  • »14.07.10 - 20:02
