Apdf 3.4 problems 1200 DPI
    Divinity
    Posts: 532 from 2009/9/8
    I have problems to view PDF at 1200 DPI with Apdf 3.4, the fonts are not viewed correctly, as damnaged fonts.
    I' don have problems to view these PDF file at 1200 DPI with other OS (OS4.1.2, OSX, Linux, Windows)
    Do you plan to update the PDF viewer in MorphOS ? or other way to solve this problem in MorphOS 2.x ?
    thanks
  • »12.07.10 - 19:35
  • rms
    rms
    Posts: 606 from 2004/11/27
    @ Divinity
    what do you mean view at 1200 dpi? Is this the number of vertical dots of your screen? The resolution of a screen is in general 75 x 75 dpi! Anyway I suppose you have a pdf file with truetype fonts and if so then they are not correctely viewable with Apdf, at least I didn't manage it.
  • »13.07.10 - 03:07
    Divinity
    @rms
    I have in Win an applacation where as print output I can create simple PDF (or PS) file (exemple with virual printer Acrobat Pro or with simple PrimoPDF...etc..) , if I create (as output) a PDF file at 600dpi I have no problems with Apdf 3.4, while if created at 1200dpi, I have not correctely viewable fonts.
    Ideas to solve this problem ?
    thanks a lot
  • »13.07.10 - 19:22
