USB Keyboard problem with MorphOS 2.5
    Divinity
    Posts: 517 from 2009/9/8
    I have a problem now with MorphOS 2.5 using an Apple white USB keyboard, sometimes It's disconnected from Poseidon (I need to remove it from USB port and connect it again).
    I use a Pegasos 2 G4@1000 (Open Firmware 1.2) and the keyboard is connected to one port USB 1.1, to the second port It's connected an Apple white USB mouse.
    (I also have a PCI USB 2.0 card, used for USB keys, hd).
    -1) I have verified with other three Apple white USB keyboard (same problem).
    -2) I have verified changing the USB 1.1 port (same problem).
    -3) I don' t have this problem using MorphOS 2.4 and 2.3, only with MorphOS 2.5.
    Any ideas ?
    thanks regards
    [ Edited by Divinity on 2010/7/13 0:13 ]
  • »12.07.10 - 19:28
