Installing TVPaint ?
    osco
    Posts: 680 from 2009/10/20
    1.5 Launching the program 9
    1.4 INSTALLATION
    1. Start your Amiga as usual.
    2. Insert the TVPaint Disk 1 into drive DF0:.
    3. Double-click on the TVPaint Disk 1 icon to open its window.
    4. In this window, double-click on the Install icon.
    The installation program will run. Follow the on-screen instructions.
    Looking at my Mac Mini from all sides I can't locate the drive DF0: ;)
    AND I don't have the TVPaint in hand ;)
    All of this in Ram: ?
    Yes the User Guide is there :) and ok
    I have downloaded three versions of TVPAINT What to do now?
    1. tvpaint-3.59.lha where the PDF User Manual is corrupted This from files on Morphzone http://morphzone.morphos-files.ppa.pl/download/TVPaint
    2. TVPaint.lha (good PDF manual but seems for an amiga with a floppy drive :(
    http://www.amigau.com/c-graphics/tvpaint.htm ty J
    3. TVPaint.zip
     :-?  :-P  :-x  :-)
    [ Edited by osco on 2010/7/2 5:15 ]
    [ Edited by osco on 2010/7/2 5:17 ]
    [ Edited by osco on 2010/7/2 5:19 ]
  • »02.07.10 - 06:10
    Jambalah
    Posts: 820 from 2008/3/30
    Well, from the start:
    Create a directory wehre you like in your hd partition (Work, Paint, Hobby etc..) and call it "TVPaint"
    Double click on 'cyber.lha' file to open (or extract to ram:): you will find the main prog executable. Place it in the TVPaint directory.
    Double click on 'tvpd1.lha' file still to open (or extract in ram:); you will find some dirs and files:
    except 'c', 'disk', 'install_TVPaint3.6' place all the others in the above mentioned TVPaint directory.
    Done!
    To avoid choosing always your preferred screen mode: open file 'TVPaint.ini' with Editor.
    Search the label [Main] and modifies the 'PageHeight' and 'PageWidth' to the screen size you like (1050x1680 f.e) and save that file (make a backup copy of the original... for emergency case).
    To launch it in automatic, without any requester, right click on TVPaint icon, select Info and Add a tooltype: SCREEN=1680x1050 and then save it.
    Enjoy!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »02.07.10 - 07:08
    Posts: 2206 from 2003/2/24
    This is the easiest option. Just unpack archive anywhere you want and run the program. No installation or anything needed. With a quick look I didn't noticed any corruption on PDF.. maybe you should download again?
    It also provides serial number, so in the first run enter any name and company you want and serial number.
  • »02.07.10 - 07:17
    Krashan
    Posts: 1107 from 2003/6/11
    MorphOS Files archive was corrupted indeed. I've fixed it right now, please redownload.
  • »02.07.10 - 17:23
    osco
    by Krashan on 2010/7/2 16:23:29
    Download works clean ty :-D
  • »03.07.10 - 00:40
    osco
    Cant find this file?
    TVPaint wont start says stack size too small?
    Icon says 42000.
    8Bit 1680 x 1050 Mode List Monitor
  • »03.07.10 - 00:48
    Jambalah
    Sorry, I forgot to write that the file 'TVPaint.ini' will be stored after the first program run.
    Then it will be stored everytime you will quit TVPaint.
    8bit...??? I've no 8 bit mode here.... Stack is the same and enough. Try a 16 or 24 bit mode.
    Pegasos II 1 ghz
  • »03.07.10 - 05:34
