Upgrading to version 2.5 of the os
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello i habe been out of the amiga for a few months as work have increased, and stumbled that a new version was released. How to upgrade to 2.5 from 2.4?. Is any advice needed?. I have mac mini and registered 2.4.
    Thanks in advance!!!
  • »27.06.10 - 13:31
    Cego
    Posts: 738 from 2006/5/27
    download and boot from 2.5 iso and choose "Update" from the installer.
  • »27.06.10 - 13:37
    amyren
    Posts: 219 from 2010/5/15
    If your Mac Mini is set up to boot directly into MorphOS, you probably need to set it back to MacOSX as default boot first.
    If not you might get an error message when booting from the 2.5 install CD.
  • »27.06.10 - 13:45
    Piru
    Posts: 624 from 2003/2/24
    Alternatively you can hit cmd-opt-o-f (win-alt-o-f) and then in openfirmware write:
    boot cd:\mac_ppc32\boot.img
    [ Edited by Piru on 2010/6/27 19:52 ]
  • »27.06.10 - 13:51
    _ThEcRoW
    Should i worry about partitions or such?
  • »27.06.10 - 14:14
    March
    Posts: 91 from 2003/7/30
    No, the installer will update only the MorphOS directory on the system partition and the boot.img file on the boot partition, keeping the backup of the older ones.
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »27.06.10 - 14:20
    _ThEcRoW
    Ok, i booted with c key pressed and disc booted ok. Clicked on upgrade and then rebooted.?Now i have my system updated with 2.5. Good work from the dev team as installation was with no problems.
    Thank for the replies!
  • »27.06.10 - 15:16
