What is neuralnet.library used for?
    insurgent
    Posts: 64 from 2007/7/8
    I'm curious what is neural network library used for? NNs are highly specialised software and its quite interesting that MOS is providing a native library that can be, I presume, used by developers to build applications that make use of neural networks. Does MOS itself uses the library?
    Registered MOS 2.7 + Pack Ultimate 1.6.2 running on:
    Power Mac G4 FW800 1.42GHz 2GB / Radeon 9000 Pro 128MB / SB Live! / NEC USB 2.0 / SuperDrive
    Mac Mini G4 1.5GHz 1GB / 64MB VRAM / SuperDrive
    Dell UltraSharp 2407WFP 1920x1200
    PowerBook G4 ready :-)
  • »20.06.10 - 09:03
    Tcheko
    Posts: 540 from 2003/2/25
    M. Banana uses neuralnet AFAIK.
  • »20.06.10 - 09:11
    Posts: 915 from 2004/1/24
    Google, I mean Aminet is your friend:
    neuralnetlib.readme
  • »20.06.10 - 13:02
