morphos 2.5 fresh install
  • TGR
    TGR
    Posts: 100 from 2009/10/26
    I decided to update my 2.4 to 2.5. so downloaded the image and burnt it. put it in the mini mac and get greeted with mophos logo screen then i get to select keyboard then I get a black screen and then this:
    iprefs
    Morphos boot.img version is too old
    in order to boot from the morphos cd, type boot/pci/cd
    to the openfirmware prompt
    tryed boot/pci/cd but comes up as unknown word.
    also ryed boot cd boot.img but says its "LOAD-SIZE too small
    [ Edited by TGR on 2010/6/7 19:32 ]
    Mini Mac G4 1.25, 1gb ram, 40 gig hdd, Registered Morphos 2.6.
  • »07.06.10 - 15:25
    Jambalah
    Posts: 820 from 2008/3/30
    Same here. So I typed boot cd/boot.img and all went ok, even installation.
    I guess it's normal, due to a boot.img enhancement.
    Edit: using a Peg II. Don't know if Mac Mini works different.
    [ Edited by Jambalah on 2010/6/7 20:36 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »07.06.10 - 15:34
  • TGR
    TGR
    Thank you tryed boot cd/boot.img but now get can't open device or file.
    so redownloading the iso
  • »07.06.10 - 15:37
    Posts: 12569 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7122&forum=3#73515
    You believe that will make a difference?
  • »07.06.10 - 16:25
    stephen_robinson
    Posts: 746 from 2007/4/22
    Tried booting from the cd by holding down the alt key and choosing the CD from that?
  • »07.06.10 - 16:29
  • TGR
    TGR
    thanks boot cd:,\\boot.img worked
  • »07.06.10 - 16:48
    XzIt
    Posts: 250 from 2005/1/19
    Had problems updating from 2.4 to 2.5 on my Pegasos 2 that is, it couldt boot the boot.img after update.
    so i just did fresh install instead and everything worked fine.
    XzIt
    Pegasos 2 G4 1 Ghz, 512mb ram, 500 gig hdd, MorphOS 2.5 Registerd.
    Mini Mac G4 1.25 Ghz, 512mb ram, 40 gig hdd, MorphOS 2.5
    Commodore 64, Amiga 500, 600, 1200, 3000, 4000, CD32, CDTV
  • »08.06.10 - 05:13
