Blackberry and MorphOS
    osco
    Posts: 680 from 2009/10/20
    Can they exchange data? :-?
  • »19.05.10 - 19:26
    Chain-Q
    Posts: 350 from 2003/10/12
    In which manner? You can plug your BlackBerry as a Mass Storage Device to a MorphOS computer, and copy data files (music, video, etc) onto it. I've a BlackBerry 8300, but i've tried various BlackBerry models as well (9500, 9000/9700, 8900 and others), they all worked fine as a Mass Storage Device with my Pegasos 2 and Mac mini, running MorphOS.
    But you can't upload software or updates from a MorphOS machine and you also can't sync e-mail, contacts, etc directly, as - to my knowledge - there's no software available for this, unfortunately.
    [.Hosting AmigaSpirit.hu.]
  • »19.05.10 - 19:54
    osco
    Blackberry 8703 connected to USB on the Mac Mini.
    Poseidon sees this device but has questions?
    There is no name: Speed:full, State: ? Running, Class: (tool icon) Vendor, Bindings: None
    Did a boo-boo fails as a Mass Storage device?
    settings for poseidon?
    [ Edited by osco on 2010/5/23 13:32 ]
    [ Edited by osco on 2010/5/23 15:59 ] :-(  :-(
    [ Edited by osco on 2010/5/23 16:01 ]
    [ Edited by osco on 2010/5/24 20:53 ]
  • »23.05.10 - 14:03
    osco
    2nd attempt to connect a blackberry rim 8703e:
    Went preferences /USB /devices.
    a table of USB devices appeared the last device on the table was the Blackberry that I had named earlier
    Name Speed State Class Bindings
    Blackberry Full Running (orange with a question mark?) Tool Icon (Vendor) None
    What has to be changed added ?
    Why is the stat in question mark?
    Why is the class a tool called vendor?
    How to I bind it as a mass storage device? it says use #0
    massstorage.class 0 Supports storage devices via usbscsi.device (MOS)
    Where is the manual?
  • »29.05.10 - 06:00
    Chain-Q
    @osco:
    Is the Mass Storage Mode enabled on your BlackBerry? Which means, is the internal storage visible form say... OSX? Or Windows? If not, you might have to enable Mass Storage Mode in the Options, but the level of MSD compatibility and availability may vary between OS versions. Please also note that a 8700 is a quite old device, with a quite old BlackBerry OS version, i've experience with newer ones only.
  • »29.05.10 - 06:13
    Posts: 12569 from 2003/5/22
    Try MOSSYS:Locale/Help/
  • »29.05.10 - 08:51
    osco
    y Andreas_Wolf on 2010/5/29 7:51:41
    Always MAGIC! Thank-you Andreas :-D
  • »29.05.10 - 09:56
