Expanding ambient shell window?
    osco
    Posts: 680 from 2009/10/20
    The output to the console is so much that the scroll can't go back to the beginning of the output.
  • »15.05.10 - 12:41
    Posts: 1521 from 2003/2/24
    You mean scrollback buffer? Go to Global MUI prefs from Ambient menu, expand class view to display all MUI classes and select PowerTerm. There is scrollback buffer setting which defaults to 1024 lines but you can expand buffer to have more lines or have unlimited scrollback buffer.
  • »15.05.10 - 16:34
    osco
    What is the exact path to this setting? How do you get to the GLOBAL MUI settings? The ambient menu? Tried but no find path? :-?
  • »16.05.10 - 16:44
    Posts: 2577 from 2003/2/24
    MMmmmm Itix did explain it quite nicely ....
    Select Setting -> MUI (this is your global MUI)
    On the left you should see a list of classes (Screen,Window,Groups ...)
    Below that frame is a button labeled "more" click that
    More classes should appear, one of them should be "PowerTerm" click that
    Now you see the options for PowerTerm-class (which is the base for the MorphOS-Shell).
    There you will find options for the Scrollback buffer, change those click save ;)
  • »16.05.10 - 18:10
    osco
    Thank-you both.. My finger is now numb from using the scrolling button.  :-D
  • »16.05.10 - 21:49
