Efika on dail-up
    Murray
    Posts: 10 from 2009/8/24
    How do I set up my Efika (MorphOS 2.4) to run on a dial-up connection? I have had it running on broadband but with so many in the family enjoying broadband it is starting to cost too much.
  • »14.05.10 - 07:21
    Posts: 2577 from 2003/2/24
    Dialup as in putting an analog modem to the serial port and start listening to those beeps (somehow I miss them ...) ?
    Well, serial-port of the Efika isn't really supported, but you might get away with some USB-serial adapter.
    How that would end up being cheaper is beyond me ....
    Or do you mean dialup as in only connect to broadband when it's really needed ? Well thats something you would have to fix in your router.
  • »14.05.10 - 09:17
    Posts: 12556 from 2003/5/22
    I couldn't stand them. That's why I muted them with the appropriate modem init string command ('ATM0' IIRC).
  • »14.05.10 - 14:41
    Murray
    Thankyou, yes I'm talking about an analogue modem connected to the serial port. I don't mind the beeps too much. On an average month we spend 4x the amount on our broadband connection than we do for dial-up. Dial-up is slower but that doesn't matter for some of our favourite sites and our email.
    I'll look for a usb to serial adapter ... or would there be a USB modem that someone could recommend to run on MorphOS. Thanks.
    [ Edited by Murray on 2010/5/15 15:04 ]
  • »14.05.10 - 23:03
    Posts: 3336 from 2003/3/5
    I'm not sure those usb <> serial adapters work. At least the ones I tried did not. Also, to get modems to work, you'd have to switch to Miami.
  • »15.05.10 - 06:14
