monitor display
    Rajinder
    Posts: 38 from 2010/3/24
    hi
    i have a dell 24" monitor(wi hub) mos sets up fine wi 1900x1200
    i also have a 28" hanns.g monitor wen i swapped monitors mos displayed 1900x1200. but after a meditating browser and a reboot the display has gone down to 1600x1200 and unless i change machine back to dell monitor i cant change the res back to 1900x1200, is this just a glitch i will have to live with or is there away to make the hanns.g see 1900x1200
  • »07.04.10 - 07:27
    Posts: 3275 from 2003/3/5
    Guess the DDC fails on the 28'' beast. In that case you should probably open the Monitor preferences, configure it manually and save that, which will disable the autodetection.
  • »07.04.10 - 11:55
