How to dualboot linux and morphos on mac mini?
    metalmac
    Posts: 87 from 2007/5/26
    Anyone that can guide me howto make a dualboot system with Yellow Dog Linux and MorphOS 2.4 on the mac mini?
    Would love to have linux instead of OSX tiger on it.
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »29.03.10 - 00:43
    Posts: 3264 from 2003/3/5
    This should essentially be almost the same as with OSX installation - the order of steps to take, etc. The only tricky bit is that the MorphOS' HD utility changes the partition order, so you have to tweak the /etc/fstab (afair that's what it was called ;) to reflect the changes done by it.
  • »29.03.10 - 06:48
    magnetic
    Posts: 2129 from 2003/3/1
    Good point the weird thing is that with Fstab the parition order is like 1 number off or something...
  • »29.03.10 - 20:52
    Is there anything different about the installation process for Dual booting if I want to add Linux as a third system to boot if I am adding it to an existing dual boot MorphOS2.4 & MacOSX Tiger installation?
    Now that I have an external 250gb hard drive and the original 80gb internal hard drive, I should have enough drive space to host all three OSes.
    I would think the ideal setup would be to have partitions for each of the boot OSes on the internal 80gb hard drive and use the 250gb external USB drive to hold my data files for all three OSes to access. Is that possible and if yes, which format can I use for the data drive/partition(s) so all three OSes can read and write to them?
    If that is not possible, I would have to duplicate my data on multiple partitions to have access from each boot OS and every time I altered one of the files I would have to somehow copy it to the other OSes data partitions if I also wanted to access that altered file from the other OSes. Does any of this make sense to anyone?
  • »29.03.10 - 22:16
    @ amigadave
    At the moment the only FS you can read & write on all three OSes is Fat :(
    As for installing all OSes, I'd start from installing OSX, then Linux, then MorphOS. All the basic partitioning can be done from Linux (similar to what I described in the dualboot guide).
  • »30.03.10 - 06:12
    Crumb
    Posts: 736 from 2003/2/24
    I have YDL and MorphOS installed in the same HD. It's not difficult to install, just remember to modify Yaboot config so it boots from MorphOS as default.
    BTW, YDL performance is disappointing.
  • »30.03.10 - 14:05
    Dreamcast270mhz
    Posts: 152 from 2009/12/8
    How do you update yaboot in linux anyhow, I made some config changes but forgot how to update it. Something involving ybin?
    My Macs:
  • »30.03.10 - 15:57
    Korni
    Posts: 473 from 2006/2/23
    "At the moment the only FS you can read & write on all three OSes is Fat :("
    You forgot about HFS or i don't know about something :).
  • »30.03.10 - 16:13
    Dreamcast270mhz
    not all Linux distros can read HFS by default, I'm sure he meant by stock, plus even FAT32 is better than HFS: 2GB Filesize vs. 4GB Filesize
    My Macs:
  • »30.03.10 - 16:17
