ffmpeg
    xyphoid
    Posts: 870 from 2008/7/11
    Is there a stable verion which works well? I'm having macroblocking issues with coverting an animated avi to mpg using FFMpeg 0.4.9-CVS170705. This version is also unstable but works after 3-5 attempts. The more recent version FFMpeg 0.4.9 pre1 complains about finding files,
    and the most recent ver. ffmpeg SVN-r18602 won't work without ixemul.library .61 or better, but these sets upsets ambient specifically shell.
    files may be found here
  • »07.02.10 - 19:45
    Posts: 12539 from 2003/5/22
    http://fabportnawak.free.fr/misc/ffmpeg.lha
    Referred to from:
    http://www.amiga.org/forums/showpost.php?p=529606
    http://www.amiga.org/forums/showpost.php?p=535021
  • »07.02.10 - 19:51
    xyphoid
    @Andreas_Wolf
    Thanks You da man, I'll try it !
  • »07.02.10 - 23:18
    xyphoid
    yea getting the same error with this too
    argument: ffmpeg -i mymorphos:file.avi -s hd1080 -target dvd seagate:file.mpg
    result:
    FFmpeg version SVN-r20529, Copyright (c) 2000-2009 Fabrice Bellard, et al.
    built on Nov 15 2009 00:16:01 with gcc 4.2.4 (Fedora 4.2.4-6)
    configuration:
    libavutil 50. 4. 0 / 50. 4. 0
    libavcodec 52.41. 0 / 52.41. 0
    libavformat 52.39. 2 / 52.39. 2
    libavdevice 52. 2. 0 / 52. 2. 0
    libswscale 0. 7. 1 / 0. 7. 1
    mymorphos:file.avi: no such file or directory
    anyone any clues?
    [ Edited by xyphoid on 2010/2/8 11:10 ]
  • »07.02.10 - 23:55
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Try with file: prefix and just in current dir for output
    ffmpeg -i file:mymorphos:file.avi -hq -target dvd file.mpg
    (it seems it doesn't like amiga volumes, not a big surprise :))
    [ Edited by Fab on 2010/2/8 2:16 ]
  • »08.02.10 - 00:11
    xyphoid
    Thanks fab,
    excellent quality on the out put.
  • »08.02.10 - 03:32
    osco
    Posts: 680 from 2009/10/20
    Curios .. ? How is the reverse play and time coding?
  • »08.02.10 - 18:28
    xyphoid
    Not sure however it seemed to match up perfectly.
  • »08.02.10 - 22:18
