First post from Efika with MorphOS!
    Tronman
    Posts: 209 from 2003/3/3
    Well, I finally got it working! The boot issues I had from USB stick persisted, but it seemed like it was down to just 'luck of the draw' whether the box would read the stick or not, and it finally did :-)
    Even with the MOS timeout, it still was able to download the iso and install. Took a few hours, but did it.
    The only issue that I now have is when I boot into MorphOS, I have to unplug the network cable untill I'm past typing the boot arguments in, otherwise I get a 'RRRRRR error: network timeout' and no boot.
    I'm not sure what to do about that other than come up with the coin to reg MOS 2.4 so I don't have to reboot as much. Maybe an OF setting I can change?
    Anyway, it's a pretty snappy little machine on the net-it won't be playing HD videos or anything, but in a lot of ways, its speed compares pretty favorably to OSX on way faster hardware.
    I've missed having an 'Amiga-like' computer on my desk. It's good to be home :-)
  • »24.01.10 - 18:47
    Posts: 2578 from 2003/2/24
    Yeah, seems you've got that little one setup to netboot.
    You need to set (useing setenv in the of) those variables:
    boot-device : the partions where the boot.img sits
    boot-file : the actual boot.img for the efika
    boot-command : the parameters you want to pass to the kernel
    (see http://www.morphos-team.net/installation.html for details)
    auto-boot-timeout : no of millsecs to wait, don't set below 1000
    auto-boot? : true
    Should do the trick.
  • »24.01.10 - 19:42
    Tronman
    Thanks, that's just the info I needed!
    Now to get that 'ca certificate' issue with OWB and Facebook fixed :-)
    Any ideas?
  • »24.01.10 - 20:09
    Krashan
    Posts: 1107 from 2003/6/11
    Go to OWB preferences, choose "Security" from the list and check "Ignore SSL errors".
    [ Edited by Krashan on 2010/1/25 7:16 ]
  • »25.01.10 - 05:14
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 15.05.2011 - 09:11 ]
    Pegasos2 G3, 512 megs RAM
  • »25.01.10 - 16:04
