MAME & Hollywood audio problem.
    Jambalah
    Posts: 820 from 2008/3/30
    Hi all!
    Suddenly, a couple of days ago, MAME stopped playing sounds. Everything works perfect but no sound at all.
    I'm using a SoundBlasterLive with emu10k and though all the programs related to sounds (AminetRadio, CDPlayer, MPlayer and so on) work well, I switched to Pegasos audio for a test. But nothing new happened.
    The same for Hollywood: when I launch a script it 's executed but no sound is played.
    Any idea?
    Thanks!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »11.01.10 - 15:01
    xyphoid
    Posts: 870 from 2008/7/11
    did you restart I mean sure you did it's just that I also noticed that if another audio source is up, sometimes mame, won't have audio
  • »11.01.10 - 22:27
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I can't tell for hollywod, but MAME uses the musical unit, that is exclusive, unless you use device.audio (which "redirects" applications using music unit to device unit).
    In any case, i'd say you probably changed something in your music unit settings.
  • »11.01.10 - 22:47
    Jambalah
    Thanks Xyphoid, I just did it but with no luck..
    Fab: propabily so does Hollywood. But I checked the settings and all seems ok..
    I tried to use music unit with AminetRadio too and I obtained a red bar after the radiostation loading and no audio...
    Pegasos II 1 ghz
  • »12.01.10 - 09:20
    Jambalah
    I changed audio mode for music unit: from Emu10k hi-fi stereo ++ to Pegasos hi-fi stereo ++ and the music unit sarted to work again! The strange thing is that all emu10k modes work well with all ahi units....
    What could cause this?!?
    Pegasos II 1 ghz
  • »14.01.10 - 10:59
