Can the timeline in Mplayer be tweaked?
    osco
    Posts: 680 from 2009/10/20
    Is there a way to finetune the time the down to frames per second?
    The gui goes now ie: 00:00:00 hr/min/sec
    How about 00:00:00:00 hr/min/sec/frame?
    http://www.mplayerhq.hu/DOCS/HTML/en/skin-file.html#skin-file-main
    Variable Meaning
    $1 play time in hh:mm:ss format
    $2 play time in mmmm:ss format
    $3 play time in hh format (hours)
    $4 play time in mm format (minutes)
    $5 play time in ss format (seconds)
    $6 movie length in hh:mm:ss format
    $7 movie length in mmmm:ss format
    $8 play time in h:mm:ss format
    Currently play time is variable ($1)?
    How much coding to tweak to variable ($5) ?
    From Read me Morphos
    Notes:
    - The GUI only allows to configure a few from the hundreds mplayer options,
    but you can still pass them in command line or in
    conf/config file like before. Options overridden by the GUI are written
    to conf/gui.conf.
    WOULD SOME GIVE AN EXAMPLE TO CHANGE THE OPTION FROM $1 to $5?
    - The preferences window is still quite basic, but may be extended in next
    versions.onward
    Ram Disk:> mplayer -input cmdlist ? no list of mplayer commands appeared? Why?
    MAIN MPLAYER SITE WORTH THE VIST
    http://www.mplayerhq.hu/design7/news.html
    SKINS
    http://www.mplayerhq.hu/design7/dload.html
    I'd like to seek +/- 1 frame instead of 10 seconds.
    A:
    You can step forward one frame by pressing .. If the movie was not paused it will be paused afterwards (see the man page for details). Stepping backwards is unlikely to be implemented anytime soon. (Quick tapping give great slow motion control from the keyboard)
    Osco ;-)  ;-)  ;-)  ;-)  ;-) test
    [ Edited by osco on 2010/1/12 22:51 ]
    [ Edited by osco on 2010/1/12 23:14 ]
    [ Edited by osco on 2010/1/13 12:24 ]
    [ Edited by osco on 2010/1/13 12:26 ]
    [ Edited by osco on 2010/1/13 12:33 ]
    [ Edited by osco on 2010/1/13 12:52 ]
    [ Edited by osco on 2010/1/13 12:55 ]
    [ Edited by osco on 2010/1/13 12:58 ]
    [ Edited by osco on 2010/1/13 13:04 ]  :-)  :-(  :-D  ;-)  :-o  8-)  :-?  :-P  :-x :bloons:
    [ Edited by osco on 2010/1/13 13:07 ]
  • »13.01.10 - 01:40
    osco
    "the most promising target group for MorphOS would be technically suave enthusiasts (in relative terms) who are likely to enjoy the advanced customization and individualization options as offered by MorphOS :flame: :flame: :flame: :flame:
  • »13.01.10 - 17:28
