Enhanced Display
    Travis_H
    Posts: 165 from 2009/12/17
    Hi all,
    What excatly does 'Enhanced Display' do in the Screens prefs?
    I have a MacMini 1.5 with 64megs of video ram and found that turning off enhanced display on all my screens sped up not only screen switching, but stopped the occasional hiccup in AMP mp3 playing.
    Am I missing some "enhanced" features by turning it off?
    Travis
  • »09.01.10 - 17:25
    Krashan
    Posts: 1107 from 2003/6/11
    Enhanced Display makes use of hardware 3D acceleration in graphics card to render all the system GUI elements. It enables things like transparent windows (for now only using Lucy commodity) and transparent window borders & shadows in some skins.
    If you prefer usability over eyecandy, turning enchanced display off is a good idea.
    [ Edited by Krashan on 2010/1/9 19:52 ]
    [ Edited by Krashan on 2010/1/10 18:05 ]
  • »09.01.10 - 17:52
    Posts: 594 from 2003/4/11
    Did you write enchanced on purpose or is it just a typo ? :)
  • »10.01.10 - 10:30
    Krashan
    @pega-1
    It is a native language induced typo. In Polish "h" and "ch" are pronounced almost identically. Fixed anyway.
  • »10.01.10 - 16:05
    r-tea
    Posts: 316 from 2005/3/27
    Ehmmm... in fact completely identically :-)
    Sorry for offtopic.
  • »10.01.10 - 20:46
