Is there a buffer in MPlayer?
    osco
    Posts: 680 from 2009/10/20
    I am getting choppy play :) Perhaps the download capacity is not adequate? Can one increase the buffer in Mplayer? ;-)
  • »07.01.10 - 22:51
    Posts: 12569 from 2003/5/22
    RTFM! And I don't even mean the large original manual but Fab's shortish readme.
  • »08.01.10 - 05:27
    osco
    by Andreas_Wolf on 2010/1/8 2:27:48
    Ty Andreas.....but I think it may be more than that :( https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=6517&sortname=&sortorder=&sortdays=&viewmode=flat&order=0&start=0
    The issue of the speed of the net connection is compounding the poor performance of MPlayer.
    as your ORDERS Osco seen heading to RTFM! again. :-?
    From the Read Me:
    'mplayer -vo help' will show you the available video output drivers. Experiment
    with the '-vo' switch to see which one gives you the best performance.
    If you get jerky playback or no sound, experiment with the '-ao' switch (see
    '-ao help') to choose between different audio drivers. Note that jerky playback
    is caused by buggy audio drivers or a slow processor and video card. With a
    good audio and video driver combination, one can play DVDs and 720x576 MPEG-4
    files smoothly on a Celeron 366. Slower systems may need the '-framedrop'
    From the "Morphos ReadMe:
    + Cache system
    Cache option is highly recommended for DVD
    playback (to compensate reading latency) or network streaming.
    Examples:
    mplayer -dvd-device ide.device:2 dvd://1 -cache 16384
    mplayer -cache 8192 mms://62.67.184.16/Game-TV (nice example to test streaming abilities)
    Andreas that's the README!
    What now Andreas?
    Osco seen headed to:
    Please refer to MPlayer documentation for exhaustive information:
    http://www.mplayerhq.hu/DOCS/HTML/en/index.html
    [ Edited by osco on 2010/1/8 6:48 ] :-P  :-P  ;-)  ;-)
    [ Edited by osco on 2010/1/8 7:00 ]
    [ Edited by osco on 2010/1/8 7:41 ]
  • »08.01.10 - 09:16
    xyphoid
    Posts: 870 from 2008/7/11
    @Andreas_Wolf
    ignorant....this is not the response one should give to relatively new users, or seasoned users for that matter damn, I hope a moderator responds...nuff said!
  • »08.01.10 - 11:27
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    @osco
    this is the "cache" option you're looking for (which is in the readme, indeed :)). You can set it directly in the gui settings. If you don't use the gui, -cache <value> can be used.
    The cache can also be configured more precisely with more advanced options like -cache-prefill or -cache-min, which are described in the official mplayer documentation (I hope, at least :)).
    [ Edited by Fab on 2010/1/8 14:53 ]
  • »08.01.10 - 12:48
    I consider it ignorant towards the program author's work to ignore his readme files and then asking questions in forums that are perfectly answered by the readme contents. That's really nothing to do with being new user oder seasoned user.
  • »08.01.10 - 23:41
    > + Cache system
    > Examples:
    > abilities)
    Yes, perfectly true. You found the well hidden hint ;-)
    > What now Andreas?
    With my help you quoted the answer to your question ("Can one increase the buffer in Mplayer?") above. You decide what's now, not me.
  • »08.01.10 - 23:50
    osco
    @Adreas_Wolf,
    Ty once again for the light that you bring to this forum.
    Your posts fully illuminate the page with your thoughtfullness and charity.
    You are right again1 Fab's "read me"
    thorough and helpful. That is why I cut and pasted them in my reply above.
    The questions asked in this forum and others are posed to obtain help but also to foster community.
    Thank goodness we have the manual but there are many degrees of perfection. One of them is to ask as a child.
    Thank-you Fab for your sufferance
  • »08.01.10 - 23:59
