Band width test Comparing MorphOS 2.4 with Mac 10.5.8 on a d
    osco
    Posts: 680 from 2009/10/20
    Here is the link:
    http://www.speakeasy.net/speedtest/
    Download Kbps:
    MorphOS 2.4 ------------------ Mac
    Seattle; 1395 --- 1082------------- 13495--- 13225
    San fran 2640--- 3282 ------------- 11766--- 11701
    LA 3216--- 3341------------- 11389--- 11633
    Dallas 3131--- 4049------------- 14104--- 15718
    Chicago 3822--- 3800 -------------- 19145--- 19637
    Atlanta 4165--- 4097 -------------- 16043--- 18882
    NY 4769--- 4459 -------------- 21169--- 19142
    Washingtn 3954--- 4353 --------------- 16622--- 19107
     :-o
    Why the disparity between the two OS's?
    I believe it affects the poor play on MPlayer? It's as if MorphOS is at Dial up Speed?
    The Cable modem is a combined model with both wifi as well as ethernet.
    There are multiple macs on the wifi
    Maybe check the bandwidth on those as well as the MacMini bandwidth on wifi
    [ Edited by osco on 2010/1/8 17:17 ]
    [ Edited by osco on 2010/1/8 17:18 ]
    [ Edited by osco on 2010/1/8 17:36 ]
    [ Edited by osco on 2010/1/8 17:38 ] :-?  :-?  :-?
    [ Edited by osco on 2010/1/8 17:43 ]
    [ Edited by osco on 2010/1/8 17:49 ]
    [ Edited by osco on 2010/1/8 17:50 ]
  • »08.01.10 - 20:00
    Korni
    Posts: 472 from 2006/2/23
    Probably You have this issue -> https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6517&forum=3
  • »08.01.10 - 21:14
    osco
    by Korni on 2010/1/8 18:14:40
    Yes! I read and reread the past thread before I posted the above new thread.
    Nothing was replied by the team? No updates, no comments, silence?
    Maybe I missed the reply that there was indeed a problem.
    Maybe I missed the reply that further feedback was needed
    Maybe I missed that testers were needed?
    It's not the end of the world but it is an "OS" issue. Indemic and needs remedy.
  • »08.01.10 - 22:41
